after you get radiator setup and working minimize it to the system tray... It will stay there the next time you launch it and you won't see it load... You can make the music not start playing when you start, there is an option for it in setup... You need to tell radiator to mute line in... I haven't used it in awhile, but when you click music after the radio is loaded I send radiator the mute command... Pretty sure I remember some options about muting inside radiator...
david
LinkBack URL
About LinkBacks
