Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Tip! Get speed cameras into Centrafuse/D3
  1. #11
    Constant Bitrate FociMan's Avatar
    Jun 2005
    Gloucestershire
    Excellent stuff. Now we're making progress... All we needed was the right person to stumble on our little thread!!
    FociMan
    Ford Focus Collection
    EPIA M10K / 512Kb / Creative Audigy NX USB
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Bluetooth GPRS Web Connection
    Centrafuse Beta2 / MapMonkey
  2. #12
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by CdRsKuLL
    you can actually get a audio alert, simply do the following
    goto C:\DestinatorApps\Destinator\Common\Favorites
    delete Auto Alert 1.dat file, rename the speedcam.dat (might be FEspeedcam, unsure which one MM creates) file created by MM to Auto Alert 1.dat, then in Fav's on cent, tick the alert1 box, if you like you can also change the alert1 icon in the same folder as above to the speedcam one.
    cdr
    And, if I remember correctly, you can change what it says as the alert as well.
    Quote Originally Posted by FociMan
    Or, all you needed was to ask the right people!
    Edit2:
    Code:
    ::MW,POI_ALERT_1*DISTANCE_TYPE_1000,0,0,141;1,"Poi Alert 1"
    ::MW,POI_ALERT_1*DISTANCE_TYPE_800,0,0,141;1,"Poi Alert 1"
    ::MW,POI_ALERT_1*DISTANCE_TYPE_600,0,0,141;1,"Poi Alert 1"
    ::MW,POI_ALERT_1*DISTANCE_TYPE_400,0,0,141;1,"Poi Alert 1"
    ::MW,POI_ALERT_1*DISTANCE_TYPE_100,0,0,141;1,"Poi Alert 1"
    ::MW,POI_ALERT_1*DISTANCE_TYPE_50,0,0,141;1,"Poi Alert 1"
    ::MW,POI_ALERT_2*DISTANCE_TYPE_1000,0,0,141;2,"Poi Alert 2"
    ::MW,POI_ALERT_2*DISTANCE_TYPE_800,0,0,141;2,"Poi Alert 2"
    ::MW,POI_ALERT_2*DISTANCE_TYPE_600,0,0,141;2,"Poi Alert 2"
    ::MW,POI_ALERT_2*DISTANCE_TYPE_400,0,0,141;2,"Poi Alert 2"
    ::MW,POI_ALERT_2*DISTANCE_TYPE_100,0,0,141;2,"Poi Alert 2"
    ::MW,POI_ALERT_2*DISTANCE_TYPE_50,0,0,141;2,"Poi Alert 2"
    141 is the name of the wav file - '141.wav' and it says 'favourites alert'. So either edit the above lines in 'DestinatorVoiceManeuvers.inf' to point to another wav file or re-record '141.wav'.
  3. #13
    Jun 2004
    The North, Manchester
    perhaps when someone gets this working they could post the edited files ???????????
  4. #14
    Low Bitrate markuskj's Avatar
    Jun 2005
    Abdn, Sco.
    Any update on this one guys - read with interest!
    Ice: Nakamichi MB100, Dynaudio 340, Genesis Dual Mono, JL 12w2, Epic 160
    Current Project: Fitting a Cologne V6 to an Eagle SS
  5. #15
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Is this posible to have the speed camera file uploaded into Delorme street atlas and Co pilot as well?
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
  6. #16
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Man I don't envy you guys across the pond. I'll be ****ed once the US adopts speed-cams. Red-light-cams are bad enough. I got one that I sware was yellow and according to the time-stamp on the 2 different pictures, it took me 3 seconds to cross the tiny intersection. I DEFINATLY didn't roll through a red at 2-MPH!
  7. #17
    Jun 2005
    Abdn, Sco.
    It is a ***** but if it was not cameras it would be unmarked police cars so I would happily chose a fixed object which can be identified on a GPS. It is the mobile units that are the real issue
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Cannot see imported speed cameras ?
    By AlCapone in forum Map Monkey
    Last Post: 06-02-2005, 03:37 PM
  3. Speed Cameras for DE
    By xequtor in forum Map Monkey
    Last Post: 03-06-2005, 08:38 AM
  4. Speed Cameras and POIs
    By DjBac in forum Map Monkey
    Last Post: 11-10-2004, 01:17 PM
  5. speed cameras
    By Bennai in forum GPS
    Last Post: 07-14-2004, 07:27 PM
