Results 1 to 10 of 17
Thread: Tip! Get speed cameras into Centrafuse/D3
    May 2005
    Glasgow, Scotland
    I guess some of you already know about this. There is a way to get speed cameras onto the map in Centrafuse Destinator.
    It will not warn you for the cameras, but they will show on the map.
    Make sure you have the latest version of Map Monkey:
    Latest hotfix: RELEASE: Map Monkey v1.1.348 (Hotfix)
    Latest speed camera dB: http://www.mapmonkey.net/
    Go to MM configuration -> Adv. GPS.
    Select Tools -> Import new cameras, and select the correct CSV file.
    Then Tools -> Copy to favourites (This might take a couple of minutes)
    Next time you use Centrafuse, make sure the imported speed cameras option is tick (under favourites)
    Now the speed cameras will be visible on the map.
    / Micke
    Constant Bitrate FociMan's Avatar
    Jun 2005
    Gloucestershire
    Excellent stuff mate. I wonder if anyone knows how to get the warnings working in centrafuse??
    FociMan
    Ford Focus Collection
    EPIA M10K / 512Kb / Creative Audigy NX USB
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Bluetooth GPRS Web Connection
    Centrafuse Beta2 / MapMonkey
    Jun 2004
    The North, Manchester
    but then your not using the integrated destinator............
    May 2005
    Glasgow, Scotland
    Hi OriginalNick2,
    I think I am? Im not lanching MM. Just using its config to import the cameras into favourites.
    / Micke
    Jun 2005
    Gloucestershire
    Micke, you are using the integrated destinator. Configuring MapMonkey differently somehow seems to alter the setup of the integrated destinator support in centrafuse.
    FociMan
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by FociMan
    That's because they both use the same files.Or should I say the Destinator files are installed in the default location by both programs.
    Jun 2004
    cool - didnt know that
    Raw Wave
    Jun 2004
    On the beach
    The warnings side will have to be coded in Centrafuse to work, this is custom, not a standard part of the Destinator frontend sdk.
    Jun 2005
    Gloucestershire
    ok thanks for that UKMP3Car. I wonder if this is planned for Centrafuse 1.3? One for David to answer I think...
    FociMan
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    you can actually get a audio alert, simply do the following
    goto C:\DestinatorApps\Destinator\Common\Favorites
    delete Auto Alert 1.dat file, rename the speedcam.dat (might be FEspeedcam, unsure which one MM creates) file created by MM to Auto Alert 1.dat, then in Fav's on cent, tick the alert1 box, if you like you can also change the alert1 icon in the same folder as above to the speedcam one.
    cdr
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Cannot see imported speed cameras ?
    By AlCapone in forum Map Monkey
    Last Post: 06-02-2005, 03:37 PM
  3. Speed Cameras for DE
    By xequtor in forum Map Monkey
    Last Post: 03-06-2005, 08:38 AM
  4. Speed Cameras and POIs
    By DjBac in forum Map Monkey
    Last Post: 11-10-2004, 01:17 PM
  5. speed cameras
    By Bennai in forum GPS
    Last Post: 07-14-2004, 07:27 PM
