Results 1 to 10 of 17
Thread: using voice in centrafuse.. how?
    Feb 2004
    North Aurora, IL
    i just got the logitech noise cancelling microphone that many of you were recommending in the other thread in the navivoice forum.
    but i cant seem to get it to work with centrafuse. I installed sapi, trained the program. I am able to toggle the "ear" in centrafuse. But it doesnt respond to any of my commands.
    am i doing something wrong? any idead
    edit: as soon as i posted it started working..... but for some reason every once in a while when i say "next song" instead of playing the next song it goes to the mixer screen, this is probably not a centrafuse thing but what sapi recognizes it as...
    I wish i knew how to do fiberglass work...
    Feb 2004
    North Aurora, IL
    can i use the built in things from centrafuse as well as navi voice at the same time?
    like use centrafuse's commands for the player, and navivoice for for like iguidance using the same "computer" recognition command or do i have to set them as two different commands?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by theheel
    I'd suggest you remove most of the commands from NaviVoice's XML file, as you're not going t obe using them. But yes, it will work.
    Apr 2005
    Queens, New York
    Quote Originally Posted by 0l33l
    Hey 0l33l,
    How do I set up navi voice where I can use centrafuses voice commands and some of navi voice's commands at the same time just using navi voice. I have an nLite system without Microsoft Speech. SO this would be cool if I can do this. Any way you can create the xml file and post it.....
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Cheekz185
    Hey 0l33l,
    NaviVoice uses SAPI just like CF. So on an nLited system, neither will work.
    CF doesn't have a SDK, so I can't put in support for CF into NaviVoice so you could just disable the integrated speech recognition.
    Apr 2005
    Queens, New York
    Is there any way i can get Microsoft Speech on there without formatting and doing another nLite...?
    Jul 2004
    Berkeley, CA
    Have never used nLite, so I don't know.
    Aug 2004
    Black Hills, SD
    I have been using nLite and the other day I was able to get speech running for CF. If you follow the posts in the nLite Safe Settings post #28, but choose not to remove Media\Speech, and System\CTF it will work just fine for you.
    Hardware: VIA Epia MS 12000, 512 DDR, 60GB HD, 7" Xenarc, GM-210, Wi-Fi, Bluetooth, Radio Xtreme
    Software: Centrafuse2, Phonecontrol.net, nLite, TopoUSA 5.0, iGuidance, Girder, Winc
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Floatingpi
    Post that advice in that thread... I'm sure many people will appreciate it
    Raw Wave
    Jun 2004
    On the beach
    It should be possible to just install SAPI, worth a go, will save you reinstalling everything again
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 07:12 PM
  2. SpeakEasy Voice Recognition - Beta 1
    By ruairi in forum Road Runner
    Last Post: 08-22-2006, 11:12 PM
  3. Replies: 21
    Last Post: 03-07-2006, 10:43 PM
  4. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  5. Centrafuse Launcher (Fixes Map Movement)
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-02-2005, 02:53 PM
