Results 1 to 10 of 11
Thread: External temperature in Centrafuse?
    Raw Wave justintime's Avatar
    Apr 2005
    Did a search, and did not come back with anything. I'm suprised!
    Anyhow, is there a clean way to embed external temperature information into CF? (Assuming I have a sensor installed, and wired to serial port or similar)
    I don't just want a 3rd party app display this within CF (as an 'external app'), but rather, would like this to temp reading to be fully embedded into the CF interface. Perhaps in the top portion somewhere, for every screen.
    The only way I can think of this working, is for CF to add full support for one of the more common temp sensors out there. I think frodoplayer does this?
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Apr 2005
    David? Anyone? Bumpitybump!
    Quote Originally Posted by justintime
    2002 Honda CR-V
    VENDOR - Centrafuse veetid's Avatar
    I have added to CF 1.3 the ability to read and display all system information, which includes CPU temp... I do not currently have anything in place to read external temperature sensors... I have no idea what sensors people are using and how you communicate with them, but if they are serial then there shouldn't be anything to it... I will look into it after 1.3 is released...
    david
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    this would help me decide if i want to get out of my car when it's somewhere around 120+ degrees outside... living in the desert sucks hehe.
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
    Apr 2005
    Thanks David. I'll do some research for you on what the most popular solutions are. I believe they are indeed Serial port solutions...
    Quote Originally Posted by veetid
    david
    2002 Honda CR-V
    Apr 2005
    David, resurrecting this thread...
    I researched, and it seems that the KIT145 temperature kit is the way to go. Some folks are using that in RoadRunner.
    Any chance a Plugin could be written for this? it is a serial port RS232 device, and it is self powered. It sends a straight text data feed, and there is an SDK available. Seems like this can be had for less than $50 shipped!
    I plan on purchasing one.
    Info at:This Page
    2002 Honda CR-V
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Actually i dont see any reason why this should be in centrafuse. I think this belongs in weather plugin.
    Apr 2005
    Quote Originally Posted by P3rv3rt B3ar
    Yeah, could be. I never said it should be in CF. I actually asked whether it could be *in a plugin*.
    Yes, weather plugin might be the right one.
    2002 Honda CR-V
    and I will be including the source code to the weather plugin with the SDK download, so it could be added...
    david
    Sep 2005
    Bay Area, CA
    david
    Where in the CF interface is this information? I can't find it.
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. Centrafuse Launcher (Fixes Map Movement)
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-02-2005, 03:53 PM
  4. Real temperature solution - what do you think?
    By dmurray14 in forum Centrafuse
    Last Post: 01-24-2005, 10:38 AM
  5. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
