Results 1 to 8 of 8
Thread: Speedcamera
    Apr 2005
    Queens, New York
    Speedcamera
    Is there any program out there to implement a speed camera into CF using iGuidance?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Nov 2004
    NYC
    what?
    Apr 2005
    Queens, New York
    U know how Map Monkey had that speed camera program. I was just wondering if iguidance can have a speed camera program.
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Jan 2002
    not everyone knows what you are talking about. it would be helpful if you would explain the functionality you are curious about iGuidance having or not having. I THINK you are asking whether iGuidance can place the location of speedcamers on top of a map, that way when you approach an location you marked as having a speedcamera, it will alert you. is this correct?
    Apr 2005
    Queens, New York
    Quote Originally Posted by amthar
    Correct
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Oct 2004
    Netherlands
    i was using mapmonkey before i used the intergrated gps.. so i imported all the speedcams into mapmonkey (it imports them as favorites) then i switched to CF and as CF also uses the SDK it just had the speedcams in the maps only thing it didn;t have was the warning.
    my destinator map resource down permanently
    Apr 2005
    Queens, New York
    But im not using Map Monkey, I dont have Destinator. I am using iGuidance
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Oct 2004
    Netherlands
    Quote Originally Posted by Cheekz185
    haha sorry didnt read as good as i should!
