Results 1 to 9 of 9
Thread: Master & Wav Volume
    Constant Bitrate snmnetwork's Avatar
    Aug 2004
    Atlanta, Ga
    Master & Wav Volume
    Is there any way to get the Master and Wav volume to turn up and down together. I have a M10000 mobo and using the onboard 5.1 sound card.
    Thanks.
    Status: [|||||||||-] 90% finished
    My 2000 Chevy Monte Carlo SS Install
    VENDOR - Centrafuse veetid's Avatar
    the mixer in 1.3 has lots of options... It has independent controls for just about everything in the mixer including front, rear, center/sub... I don't currently have any logic in place to raise the anything other than the master volume with the global volume controls...
    I could see having it raise the front, rear, center/sub the same amount as you increase the volume, but not sure why you would want to tie in the wave...
    david
    Mar 2004
    Quote Originally Posted by veetid
    david
    Hi David,
    Have you considered "mixer presets" for the next release? I listen to some a bunch of different genres of music, and for each I'd want to adjust the amount of output to various channels. It would be handy to be able to press one button to adjust mixer settings.
    1997 Acura 1.6 EL
    Ampie Case, Epia SP13000, 1G ram, 80g 2.5" HDD, Tripnav GPS, Lilliput 7" Touchscreen, M1-ATX
    mixer presets already added.. you can make custom and it comes with some standard ones... rock, etc...
    david
    Aug 2004
    Atlanta, Ga
    Hi Thanks for the reply. The problem is, when I lower the volume, only the lf, lr lower. Ithink the master controls one side and the wav controls the other. When I use wmp, divx player, 4am music console etc. The volume works fine.
    I only get this problem using Centrafuse and Frodo.
    I remember downloading a patch from this site that allows the Master and WAV volume to lower and raise at the sametime in Centrafuse and Frodo. It worked perfect, until you restart the comp tho. Then back to normal
    guess I'm not sure how the 5.1 works... What exactly does the wave control in relation to 5.1? On my VIA there are independent controls for Front, Rear, Center/Sub... I use all three for output and dont' use wave to adjust any of them...
    david
    Nov 2002
    Vermont, yay.
    Time to revive an old thread...
    Just installed Centrafuse on my carputer (VIA Epia M10000 board), and I have this same problem. The volume up and down buttons only seem to control the Front Speakers (verified by looking at the mixer in centrafuse). The wav channel seems to be the only volume control that will control all speakers, and that's what we M10000 users want. Anyway to allow this, or link front/rear volume adjustment? I'm not sure what it is with the simulated 5.1 sound, but I've had this problem with frodoplayer, roadrunner, and media engine. Only Mobile Media Center had the volume adjust the wav, so I know it's possible.
    Mar 2004
    New Jersey
    Quote Originally Posted by snmnetwork
    Thanks.
    You need frodo's matchvol.exe do a search and you will find it. It runs in the background and locks the master and wave together.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I hope 1.5 will add smoother volup-voldown events, we talked about logaritmic increase, it wolud be so nice..
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  1. master volume
    By funkeq in forum Input Devices
    Last Post: 10-11-2006, 07:04 AM
  2. Problem: Master Volume at 100% at startup
    By digitboy74 in forum Road Runner
    Last Post: 05-03-2005, 02:24 PM
  3. Adjusting Volume Level According to Master Volume
    By Xtreme2k2 in forum Software & Software Development
    Last Post: 10-02-2004, 11:51 AM
  4. Balance and master volume interaction...
    By millovanillo in forum MediaCar
    Last Post: 08-16-2004, 12:22 PM
  5. The volume question: MASTER vs. WAVE
    By tbdombrosky in forum Software & Software Development
    Last Post: 07-19-2002, 02:59 AM
