Bugs so far in 1.3 BETA
ok i found 2 bugs so far
1. pressed system info a loading screen came but centrafuse just froze had to exit via the task manager
2. press the 'eye' twice and you get this error [image attached]
Code:See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at centrafuse.main.systemCommands(Int32 command)
at centrafuse.main.visBtn_Click()
at centrafuse.main.main_MouseUp(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at centrafuse.main.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
centrafuse
Assembly Version: 1.3.2021.30940
Win32 Version: 00001.00003.02021.30940
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/centrafuse.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
ReflectionCleaner
Assembly Version: 1.0.0.0
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
cfplayback
Assembly Version: 2.1.0.5
Win32 Version: 2.1.0.5
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/cfplayback.DLL
Xheo.Licensing
Assembly Version: 2.1.5000.0
Win32 Version: 2.1.5000.26c
CodeBase: file:///c:/windows/assembly/gac/xheo.licensing/2.1.5000.0__798276055709c98a/xheo.licensing.dll
System.Web
CodeBase: file:///c:/windows/assembly/gac/system.web/1.0.5000.0__b03f5f7f11d50a3a/system.web.dll
System.Web.Services
CodeBase: file:///c:/windows/assembly/gac/system.web.services/1.0.5000.0__b03f5f7f11d50a3a/system.web.services.dll
Microsoft.DirectX.AudioVideoPlayback
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Microsoft.DirectX.AudioVideoPlayback.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
Freedb
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Freedb.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
