When trying to select multiple directories in the directory list view, I got an unhandled exception "Font 'GE Drover' doesn't support style 'Bold'" using the default skin.
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Font 'GE Drover' doesn't support style 'Bold'.
at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
at System.Drawing.Font.Initialize(String familyName, Single emSize, FontStyle style, GraphicsUnit unit)
at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit)
at centrafuse.zListbox.OnPaint(PaintEventArgs pe)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Label.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
centrafuse
Assembly Version: 1.3.2021.30940
Win32 Version: 00001.00003.02021.30940
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/centrafuse.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
ReflectionCleaner
Assembly Version: 1.0.0.0
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
cfplayback
Assembly Version: 2.1.0.5
Win32 Version: 2.1.0.5
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/cfplayback.DLL
Xheo.Licensing
Assembly Version: 2.1.5000.0
Win32 Version: 2.1.5000.26c
CodeBase: file:///c:/windows/assembly/gac/xheo.licensing/2.1.5000.0__798276055709c98a/xheo.licensing.dll
System.Web
CodeBase: file:///c:/windows/assembly/gac/system.web/1.0.5000.0__b03f5f7f11d50a3a/system.web.dll
System.Web.Services
CodeBase: file:///c:/windows/assembly/gac/system.web.services/1.0.5000.0__b03f5f7f11d50a3a/system.web.services.dll
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.3052.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
Microsoft.DirectX.AudioVideoPlayback
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Microsoft.DirectX.AudioVideoPlayback.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
Freedb
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Freedb.DLL
RegexAssembly1_0
Assembly Version: 0.0.0.0
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Edit: Also, the option to replace the system shell doesn't work. It still loaded Explorer after I rebooted
Edit2: Yes it does, I was just being stupid, however once in this mode the behaviour of the exit button is broken. It should either power down the system, or perhaps more usefully, fire up Windows Explorer, then exit. Currently if you hit this button then ctrl+alt+del is your only way out
