Page 17 of 17 FirstFirst ... 7891011121314151617
Results 161 to 170 of 170
Thread: CF BETA 2 [1.3] Requests
  1. #161
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    I apoligize if I insulted your coding skills with the reference to the other program. I by no means meant to.
    My computer automatically hibernates when I shut the car down, but this is only because it is faster to come back from than a cold start. So, I would think a feature like this would be like 'start in media manager' so I, like the others who shutdown completely, can choose to start in media every time. This would obviously have to be optional as people like yourself don't want it to do that at all. That was just my thought process on this feature request.
  2. #162
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by donde
    I wasn't insulted at all... it's all good... I have added an option in the upcoming release to auto start in any section... including available external apps...
    david
  3. #163
    Raw Wave justintime's Avatar
    Apr 2005
    David, interesting... Autostart, when exactly? When the program is first launched, when resuming from hibernation, both?
    Quote Originally Posted by veetid
    david
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #164
    Quote Originally Posted by justintime
    from a fresh load you can choose what section centrafuse starts in... hibernation will work like hibernation and bring the computer back to where it was when you hibernated...
    david
  5. #165
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    david, I think it would be useful to add an option to select if close an embedded app when switching to another (or to media)
    maybe an xml tag in the external section.. it would be useful because I plan to use a couple of programs which both use overlay function and they cannot run in the same time.. don't know if this can help other people
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  6. #166
    Apr 2005
    County Durham, UK
    David, please can we have keyboard shortcuts for all buttons on this screen?
    Shortcuts for all buttons would be great. For me these ones are a must.
    Using a shuttlexpress in a car works great and this screen is the one I need to use it with most.
    Thanks in anticipation.
  7. #167
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I second that request. You should really be able to navigate the entire interface using Up, Down, Left, Right, Enter, and Escape (Plus maybe Tab and Shift-Tab to move from the left nav buttons, to the current window, to the bottom buttons, to the top buttons).
  8. #168
    Apr 2005
    County Durham, UK
    Hey RPM VR4, sounds like we're on the same page!
    When keyboard shortcuts are available/configurable for all buttons I'll invest in a Shuttle pro that has more buttons. It really is an awesome piece of kit.
    Th only problem is that this side of the pond you reall have to use it with the left hand, which, being right handed, takes some getting used to.
  9. #169
    Nov 2004
    L.A.
    Hehe, I'm left handed and have to use my Griffin PowerMate with my right.
    See if your device has a Girder Plug-In. If it does you can script everything via the mouse, but it would be easier/better with keyboard num-pad navigation or something.
  10. #170
    Apr 2005
    Some suggestions about embedding
    Hi Veetid,
    There are some suggestions of features I would love to see in Centrafuse related to apps embedding :
    - Feature to automatically detect a software title using a partial title, in exemple for embedding Net Stumbler who use a timestamp in the title. This could be a set on/off in the external.xml config file, in example : <PartialTitle>true</PartialTitle> or <PartialTitle>false</PartialTitle>.
    - Feature to set what action to do when we press on the Close button when in full screen. This would be to set if I want that centrafuse close the application by killing it or by closing it. I found that Microsoft Streets & Trips always give an error when closed through the Close button and CoPilot also isn't properly closed. The close method could be set in the external.xml config file, in example : <CloseMethod>KILL</CloseMethod> or <CloseMethod>EXIT</CloseMethod>,
    - Feature to automatically detect if the current software was closed and if its the case, either do the same thing than the Close button or automatically restart the application. The action do to when the application is closed (from the app, not CF) could be set in the external.xml config file, in example : <OnClose>RESTART</OnClose> or <OnClose>CLOSE</OnClose>.
    - Also, I'm currently having a problem to embed the Planning mode of CoPilot of Centrafuse, I use the title CoPilot and this working okay but not all the times. Sometimes CoPilot is embedded, sometimes not. So if you could take a look to this problem I would appreciate this because I really want to have CoPilot embedded in Centrafuse. I know that the Guidance mode can't be embedded but I use it OnTop of Centrafuse so this isn't a problem.
    Thanks,
    Daniel
  1. Flash card bootable drive?
    By The Durango Kid in forum General Hardware Discussion
    Last Post: 03-16-2005, 09:20 AM
  2. lastest destinator Beta doesn't always close.
    By bertybassett in forum Centrafuse
    Last Post: 01-17-2005, 04:31 PM
  3. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  4. Flash OS
    By BiohazrD in forum General Hardware Discussion
    Last Post: 12-04-2004, 09:57 AM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
