Page 7 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 61 to 70 of 170
Thread: CF BETA 2 [1.3] Requests
  1. #61
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    This has probably been mentioned but I really want to turn off that annoying startup sound
    If you delete the wav file the program just generates a new one
    I also think that there should be an option to either show the album art view or show a text list view
    I also would like to see the font size of the album text in album art view increased
  2. #62
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    david, I want to point out some ideas, it's not a bug but a "way of use" in the apps section
    1) I embed my MapStore GPS software into APP1 button but when I go to Media and back to Apps I also have to press APP1 button to have my GPS on screen
    It will be cool if when you press Apps button in the main screen it goes straight to the las used application window; if you press Apps again it would go to the Application List page.. this way you will avoid two clicks plenty of times
    2) I admin I would have loved if VIDEO and DVD had been coupled into the same button, it would have been much easier and faster to select videos quickly
    3) if you are listening to a song and you scroll down a couple of pages, the "highlighted song" line followe you and moves from the current song, so when you press NEXT it jumps to the wrong song.. it would be mice to have a small toggle button to lock the current playing song in the center of the list (and the window) and make the whole list scroll up (or down in case you press the PREV button); if you want to see the queue list you could use the scrolling button but after a certain amount of time it should go back to the current song position placing it in the center of the screen list.. I home I made myself clear
    it would also be cool to be able to move the songs up and down in the queue directly from the list preview during the playback
    4) I really don't need the SAPI support so the bottom right icon is not useful for me, it would be good to have this icon customizable with a function (maybe EXIT of whatever)
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  3. #63
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Great re-write David, miles faster and more responsive now. @Ebomb - I also like the look but where are the different colour skins
    I have noticed some minor issues though;
    * If you press the + button in Directory view when in the root folder not in an album folder it loads every album I have. That tends to make my PC cluggish for about 2hours as I have one media folder with 190Gb of music sorted into sub dirs by artist/album. The problem arises when you want to remove them again, ONE BY ONE. Arggg, is there anyway to just clear the list other than using taskman to forcefully close CF?
    what tittle is CF looking for for album art cause all mine don't show. They are called front.jpg and back.jpg so I can change it to show front or back covers - (handy for unnamed mp3's).
    I tried a txt search to find the reference to album art jpegs with no luck
    It would also have been nice as mentioned above to be able to add apps through setup.
    I know you have issues with powerloc but could we be able to use D3 as in CF1.2 or even just embed MM/FD or can it only be done through ext apps.
    What about Rev Camera, I thought that would also be included...
    My video files also play without sound in CF but work ok in all my other players
    There was something else but my mental storage alogorithms have many bugs and bad sectors, the old grey lump could do with a good Defrag & Scandisk too - especially after a session drinking Stella and smokin green
    Don't feel like Im moaing cause im not, Im really impressed with CF upto now. Keep up the good work.
    John
  4. #64
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    Rickster
  5. #65
    Apr 2005
    Queens, New York
    Quote Originally Posted by Tuned Vitesse
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  6. #66
    VENDOR - Centrafuse veetid's Avatar
    John
    To remove all the songs from your queue simply delete it... it will auto recreate an empty one... Click playlists, highlight queue, and hit remove...
    CF looks for folder.jpg or the name of the file.jpg, same as XP...
    I do plan on adding external config to setup... it's a BETA.. not everything is finished..
    You can embed MM/FD just fine as an external app and it will function just about as good as it would integrated...
    Rev Cam will be a plugin... again.. not finished... this was an early pre-release to see the progress so far...
    not sure about the video files problem...
    david
  7. #67
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    Quote Originally Posted by RPM_VR4
    Donde: If you are happy with the volume as buttons (as long as it goes faster), then wouldn't you be happy with the page buttons made so it continually smooth-scrolls the list when held down.
    Yeah that'd be good too, I don't have any strong opinions for or against the ipod wheel. Even if scrolled entire pages instead of smooth scrolling, that would be fine, as long as you can just hold down the botton to continue to scroll through pages or songs instead of pressing it for every page.
  8. #68
    I actually had the page up/down buttons scroll the listview when you held them down... I had them gradually increase the speed the longer they were held down... I had to take it out because of performance... It required a lot of processing power to scroll that list really fast and paint all the anti-aliased text and it's background.. It was really intense when holding them down in album art view in the media manager... It only worked properly with about a 1.6ghz processor or higher... I plan on trying to optimize it, but my goal was for this too run well on an M10000... so it was removed...
    david
  9. #69
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    It is more important for the "now playing" than the "media manager". I would just not show the images while scrolling.
  10. #70
    Jun 2005
    Phoenix, AZ
    David, if you do add more power intensive features, please make them a configurable option. As of now all your features work on my 600mhz laptop as i've said before. I'd hate to have to change programs (or more likely buy a new computer )
  1. Flash card bootable drive?
    By The Durango Kid in forum General Hardware Discussion
    Last Post: 03-16-2005, 08:20 AM
  2. lastest destinator Beta doesn't always close.
    By bertybassett in forum Centrafuse
    Last Post: 01-17-2005, 03:31 PM
  3. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 06:48 PM
  4. Flash OS
    By BiohazrD in forum General Hardware Discussion
    Last Post: 12-04-2004, 08:57 AM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 01:20 PM
