Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: CF requires a 1GHz processor?
    Jun 2005
    Phoenix, AZ
    David,
    I see on the website you list "1Ghz processor or higher" as a requirement. Why is this? My 600Mhz laptop can run GPS software, play music, play DVDs / Video files. Why would I need that powerfull of a computer? And also, 256 MB of RAM?? Thats huge! Are you sure those are minimum requirements?
    Scott
    Elsewhere
    Quote Originally Posted by spdyscotty
    To run Centrafuse.
    He's the developer. I'm quite sure he's sure.
    How about the Wiki?
    Jun 2005
    Phoenix, AZ
    If this is true I can't run this on the laptop I was planning to use. Bogus.
    VENDOR - Centrafuse veetid's Avatar
    Just try it, but CENTRAFUSE runs on Windows XP, which runs MUCH better with 256 over 128... I know I wouldn't run XP with 128... The memory requirements are all on the OS... The processor speed I just put... I have run it on an 800mhz and it worked fine... I just recommend a 1ghz or higher... Not saying it will not work on a slower machine...
    I also did that website in 2 days with no sleep... I will be finishing it and spending more time on the details...
    david
    Oct 2004
    NY
    if your running xp, 256 is far from huge.....bare minimum I would say.......& I really wouldn't want to use any less than 512 on an xp machine if I had the choice...that's when xp will start to shine......xp loves ram...regardless of the apps your running
    Jun 2005
    Phoenix, AZ
    Okay, I have to reinstall XP as I have some major issues right now. CF will not run but it's because my machine is all bugged out from the insane amount of crap on it. The older version of CF worked fine until the machine bugged out. XP runs with no problems at all (until I tried to hack something and F'ed it up). I'll let you know how it turns out. Maybe you could make a "minimum requirements" and a "recommended requirements" section?
    I'll let you know how it runs on my machine once I reinstall everything.
    sounds good... what is on the website right now is recommended... Minium I would say is 600mhz - 800mhz with 128 megs of ram...
    note: basically if you can run XP then you can run CENTRAFUSE...
    david
    Jun 2005
    Phoenix, AZ
    Sounds good!
    Jun 2005
    Phoenix, AZ
    Also, according to Microsoft, the recommended minimum is 128MB Ram and 300mhz processor. Although that processor speed will most likely be insuffient for playing high quality video and maybe even high quality audio. If XP is only being used to run a couple apps, I see no reason why 128mb RAM wouldn't be suffient. Microsoft in fact stated the OS will run with 64mb but 128 is recommended.
    just speaking from personal experience from hundreds of computers at my office... Windows XP needs 256megs and doesn't run good until you give it 512... Microsoft is wrong...
    david
  1. cf newbie question
    By chrislloyd in forum Centrafuse
    Last Post: 03-24-2005, 05:01 PM
  2. Flash card bootable drive?
    By The Durango Kid in forum General Hardware Discussion
    Last Post: 03-16-2005, 08:20 AM
  3. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 06:48 PM
  4. Flash OS
    By BiohazrD in forum General Hardware Discussion
    Last Post: 12-04-2004, 08:57 AM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 01:20 PM
