Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: CF 2.0: Language & Keyboard files
  1. #11
    Low Bitrate mrsony6's Avatar
    Nov 2005
    Munich (Ger)
    Ok thanks for your answer!
    Did you know when this update comming?
    WFR I
  2. #12
    ret
    ret is offline
    Registered User
    May 2005
    Vienna
    is there no special character support, like in 1.4 (ö ä ü Ö Ä &#220?
  3. #13
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Quote Originally Posted by ret
    is there no special character support, like in 1.4 ( )?
    There is. Is all same than in 1.4. its just bit tricky cause u have to use unicode entities in xml file, just like in 1.4.
    Im working on finnish translation. its just bit slow cause ive got so many things going on... but ill try to finish it on weekend. GPS plugin is already ready, but i think theres no point to release it before centracore translation
  4. #14
    ret
    ret is offline
    Registered User
    May 2005
    Vienna
    i tried to add special characters to my language file but with no success. whenever i added a to a string in the language file, all buttons in CF gone blank. also tried xml codes. i. e.: &uuml
    everything worked fine in 1.4!!!
    can someone check the files?
    thx
    Attached Files Attached Files
  5. #15
    Nov 2005
    Munich (Ger)
    - keyboards does work in 1.5
    - languages dosn't work by 1.5 from 1.4
    Did someone know when this languages come?
    Best reguards
  6. #16
    Jul 2005
    Funland
    thx
    I checked ur files and u have replace every character with entities... not just first one u silly
    Anyhow i just got finnish file ready and appear on CF also after xml validation. Have to still see that fields will roughly fit and that spelling is somewhat correct... and then release
  7. #17
    ret
    ret is offline
    Registered User
    May 2005
    Vienna
    I checked ur files and u have replace every öäü character with entities... not just first one u silly
    ok, this makes sense to me .
    but in the 2nd file (Germanuao.xml) there are no special chars and it doesnt work.
  8. #18
    VENDOR - Centrafuse veetid's Avatar
    get a nice XML program like XMLSpy
    http://www.altova.com/support_freexmlspyhome.asp
    therefore you can verify the XML is valid... if the XML is not valid, then it will not work... XMLSpy will tell you what is wrong with the XML...
    david
  9. #19
    Jul 2005
    Funland
    i tried to add special characters to my language file but with no success. whenever i added a äöüÄÖÜ to a string in the language file, all buttons in CF gone blank. also tried xml codes. i. e.: &uuml
    thx
    Oh, and btw... i might be wrong, but i think entities like ü exist only in HTML, i think in xml u have to use entities with unicode references of form &#xxxx;
    for example:
    ö = ö
    ä = ä
    EDIT: damn forum converted my references to characters
    so replace xxxx with 228 for small ä and 246 for ö.
  10. #20
    Jul 2005
    Funland
    release for CENTRAFUSE v1.5 :
    Suomalainen kieliversio / language version of Fine Land (proud homecountry of 170,000€ speeding ticket... yes u r reading right thats more than US$200,000 )
  1. Laptop keyboard to the PS2 port....
    By claylong in forum General Hardware Discussion
    Last Post: 09-22-2007, 07:29 AM
  2. virtual Keyboard 1.0
    By SilentAdmirer in forum V.O.I.C.E.S
    Last Post: 05-08-2007, 09:21 AM
  3. 2 part question (keyboard hacks)
    By chuckctv in forum Input Devices
    Last Post: 09-07-2004, 09:24 PM
  4. mini keyboard
    By Alphared in forum Input Devices
    Last Post: 07-27-2004, 11:32 AM
  5. Disabling BIOS keyboard error?
    By Squeezer in forum General Hardware Discussion
    Last Post: 02-02-2001, 09:29 AM
