Results 11 to 20 of 25
Thread: Best DVD decoder to use?
  1. #11
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    If I were you I would stay away from those codec pck, they are known to cause crappy playback and other strange problems
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  2. #12
    Mar 2005
    Fixing dvd volume issue
    The reason your dvd volume is so low is because DVD audio is AC3 audio. You need to go into control panel, AC3 settings and tweak the master volume up a bit. I normally tweak mine up 10dB or so. Also, klite codec packs are great for heaps of xvid, divx movies etc, but will not help you as a DVD decoder. on the Codec pack front I personally have found DefilerPak to be superior to the k-lite codecs.
    JH
  3. #13
    Mar 2005
    DVD decoders
    Also in the Home theatre PC community forums that I frequent, the nVidia DVD decoder is by far the most highly acclaimed!
  4. #14
    Jun 2005
    Phoenix, AZ
    haak - Thank you, this is very good info. One question... in the control panel, where can I find AC3 audio?
    Scott
  5. #15
    Mar 2005
    AC3 in the control panel
    It's actually called "AC3 Filter", its the first item in my control panel. If you don't have it you can install it by installing the defilerpak I've previously mentioned. If you don't want to install a whole other load of codecs, download DefilerPak, and just go through setup only checking "AC3Filter" to install. Whalah DVD audio controls in your control panel.
    JH
  6. #16
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    All I keep getting for wmp is "Windows Media Player cannot play the DVD because a compatible DVD decoder is not installed on your computer."
    please help.
  7. #17
    Mar 2005
    Maryland
    I have installed codec's and they dont seem to do anything...
  8. #18
    The land of polar bears and nekkid blonds
    Quote Originally Posted by Escalade182
    What codecs have you installed ?
    Have you tried installing a dvd "player" such as PowerDVD / WinDVD ?
    Mixing codec-packs is a no-no, it's not a case of the more the merrier.
    Try and uninstall everyithing and then just install one pack that you trust.
    Now a lot of people would say "oh no... codec packs are evil", well, I use my own since I got tired of installing a bunch of codecs manually every single time... it does exactly the same job as I used to do manually, but now its compiled with a script into an .exe installer does that make it evil ?
    /M
  9. #19
  10. #20
    Quote Originally Posted by coucouillu
    Does anybody knows VLC (Video Lan)
    As a player it's not very good, as a concept, it's very good.
    Good for some, worthless for others, pointless in CF.
    /M
  1. Which DVD decoder
    By n8scstm in forum FrodoPlayer
    Last Post: 01-03-2005, 01:16 PM
  2. Where To Put DVD Decoder?
    By nFiniteTuning in forum XP MCE
    Last Post: 11-04-2004, 12:17 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  4. LCD Controller and DVD Decoder
    By berniejr in forum General Hardware Discussion
    Last Post: 03-08-2002, 10:23 PM
  5. USB DVD decoder
    By tyanni in forum General Hardware Discussion
    Last Post: 11-30-2001, 04:09 PM
