Results 1 to 10 of 10
Thread: I mite be an idiot but ?
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    like i said idot or not but i feel i must ask
    if i was running cf as a shell is it or could it be possible
    to run explorer as an external app in it
    FIRE AWAY
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
    Raw Wave tj!2k4's Avatar
    Oct 2004
    yes.
    Nov 2004
    southampton (UK)
    yes i am an idiot or yes it could be done ?
    and i dont mean IE i mean full explorer.exe start button and everthing (windows)
    The car
    VENDOR - Centrafuse veetid's Avatar
    what do you think about having exit launch explorer.exe when running shell mode?
    david
    Nov 2004
    southampton (UK)
    would be nice if i could keep CF running and then close explorer when finished (keeping cf up and running )
    so i guess running it as an app is not poss then ?
    The car
    not sure... it might work... go for it...
    note: I don't know what the window name would be to embed... It would launch it anyway and get a handle to the process, so it should be able to close it as well... just not sure about embedding it...
    david
    Oct 2004
    with my "yes" i meant that it's possible to embed windows explorer in cf. i was playing with that earlier.
    Oct 2004
    here's the code from the external.ini:
    Code:
    	<APP4>
    		<PATH>explorer.exe</PATH>
    		<WINDOWNAME>My Documents</WINDOWNAME>
    		<DISPLAYNAME>EXPLORER</DISPLAYNAME>
    		<PAUSEMUSIC>False</PAUSEMUSIC>
    		<LINECONTROL>NONE</LINECONTROL>
    		<STARTFULLSCREEN>False</STARTFULLSCREEN>
    	</APP4>
    Aug 2004
    I don't think he meant Windows Explorer (to browse files)
    I think he meant explorer.exe, so if you run it as a shell, you can open the start menu, desktop ..... ....
    I'd also like to know how..
    Oct 2004
    gotcha, i did miss the start button part. but if you can run explorer and browse files you are already able to access most, if not all of the functionality within windows..
  1. Replies: 7
    Last Post: 03-22-2005, 01:45 PM
  2. Newbie idiot stupid Volt/Amp question
    By Iceman in forum Newbie
    Last Post: 04-17-2004, 12:16 AM
  3. Replies: 23
    Last Post: 04-16-2004, 01:53 AM
  4. Help Help Help Help Help I Am An Idiot
    By Porgieanne316 in forum LCD/Display
    Last Post: 03-02-2004, 10:28 AM
  5. I feel like a real idiot because I cant get my inverter to work
    By gilly101 in forum General MP3Car Discussion
    Last Post: 01-31-2001, 05:44 AM
