Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: How do I run things on startup???
  1. #11
    VENDOR - Centrafuse veetid's Avatar
    they will be in 1.5...
    david
  2. #12
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by veetid
    I will make another xml file you can edit to add parameters to launch something at start, resume, and exit....
    david
    Cool!!!
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  3. #13
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Awesome. If 1.5 makes the same amount of "changes for the better" as 1.4 was for 1.3, you should have the main program "ready-for-primetime" as they say (it will just be the plugins that are beta). I can't wait to get some sample source so I can start comming up with 1-million requests for the plugin-archetecture .
    BTW: Awesome move putting Exit/Shutdown/Hibernate in the button-config. For some reason I always click Home or Apps before remembering that Exit is on the Tools window. Now it's on all 3 LOL. I'll remove it from the other 2 once I am done needing to exit all the time in order to tweak settings and skins (should be about 2 months after you are done with 2.0 and have no 2.1 betas yet ). Anyway, I say put as many possible commands in to buttonactions.xml as you can possibly think of. And make more of the buttons in to the xml too so that we can custom configure it all (phone, speech, gamma, FF, REW, eye, and all volume buttons are all things that some people need and others don't).
    PS: It would eventually be nice to be able to configure all of that from within some advanced settings mode in CF, rather than having to edit XML files in a seperate app and with CF closed. I know, I know... the requests never stop coming do they? I just love "feature creep". I have been meaning to do a lot of this in SKINbedder myself, but I have to focus on getting a new skin method for v3.0 done first, so I do realize "configuration UI" does have to come later (once the configuration stops changing LOL).
  4. #14
    Nov 2004
    L.A.
    david
    I was thinking about this and being able to customize Start, Resume, and Exit scripts is definatly cool, however, when CF is set to run as the shell, I still think it should just automatically run everything in the registry under RunOnce and Run (plus maybe everything in the All Users StartUp folder).
  5. #15
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Quote Originally Posted by anky1
    if you make a script the shell... and say the script says
    Run CF
    Run Girder
    Run Delorme
    try that?
    edit
    good call frankino i r teh reading noob
    This script only runs when the system boots from scratch right? When the system resumes from hyber, standby is there a way to execute this script?
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
  6. #16
    The land of polar bears and nekkid blonds
    Bit late I know... but use FireDaemon http://www.firedaemon.com/
    and run your "extras" as services.
    /M
  7. #17
    Nov 2004
    L.A.
    Here a new but somewhat related request... When you exit CF it auto-runs explorer, but that just brings up an explorer window, not the explorer shell. Anyway to fix that?
    It would be really cool if I could just run an explorer SHELL embeded in CF .
  1. Rage against some stupid things
    By kraft in forum Off Topic
    Last Post: 11-07-2004, 04:29 PM
  2. Funny things found in 109
    By Don 944 LA in forum FrodoPlayer
    Last Post: 10-20-2004, 12:13 AM
  3. ATX auto startup circuit
    By spud in forum Power Supplies
    Last Post: 05-09-2004, 12:40 AM
  4. Those who run fans for cooling??
    By osirisdon in forum General Hardware Discussion
    Last Post: 06-12-2003, 08:30 AM
  5. Configuring old computer to run mp3's in car
    By Blake in forum General MP3Car Discussion
    Last Post: 02-23-2003, 09:57 AM
