you should just save the file to the root of centrafuse
don't modify the file or rename it.
edit: It should be emailaddress_centrafuse.lic
what do i save the licence file as when it opens up as a page of code, and then where do i put it to get CF to recognize it?
it sounds like it saved it as .lic.xmlOriginally Posted by Tim97rs
you'll need to show file extensions and remove the .xml from the end so it just reads emailaddress_centrafuse.lic, as rickster said.
Disregard.... ver. 1.31 comes out in the next day or two , and won't require licence
Just on a side not, ,it seems like to me the majority if not all the *.lic file problems is related to when or how they are saved. I myself had a problem at first as well. It turns out that the when you open the files in a web browser or whatever and do a "Save" or "Save As" it seems that HTML or other tags are added to the file that should not be there.
So, when you go to save the file, make sure you guys save the file directly from the email without opening the file otherwise you will have problems.
Mark
Website: http://www.greenpowerenthusiast.com/
Car'Puter Project
- Xenarc 700TSV
- MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
- 1x 256MB Corsair XMMS DDR400
- M2-ATX
- Belkin 802.11G W-Nic
- Garmin 15H GPS
- WinXP SP2 (NLited)
