Results 21 to 30 of 33
Thread: Release 1.4 CENTRAFUSE BETA 2
  1. #21
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by knubile
    The serial emailed to me doesn't work. Is there a way I can get another one?
    I tried the lic file I got for BETA3 as well. no dice.
    did you install to the same location as 1.3? Try to uninstall and make sure to completly delete the directory to remove any potential hidden files from 1.3.. reboot... reinstall 1.4 and give it a shot.. Something is causing the serial not to validate... if that one doesn't work a new one will most likely not either... we need to figure out why the one you have doesn't work...
    david
  2. #22
    Maximum Bitrate knubile's Avatar
    I uninstalled. deleted the folder, then installed 1.4. Do I need a reboot between the uninstall of 1.3 and the install of 1.4?
    More importantly. Do I need that reboot between removing and installing 1.4?
    thanks
  3. #23
    thanks
    can't hurt... go ahead uninstall, delete the folder, reboot, and try to re-install...
    note: make sure you fill in the name field in registration also...
    david
  4. #24
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Good job on the update! I'll have to go through it and see if I have any of the problems from before..
    Though i'm not fantastic that you changed the way the skins work.. Especially for the background logo. Why everything .PNG?
    Bah...another hour or two trying to rebuild my 1.3 skin..
  5. #25
    Quote Originally Posted by Jahntassa
    PNG is a much better format. I actually have no idea why I used jpg before... PNG is lossless... JPG is a very lossy format.. I needed to support transparency for the playcontrols in order for them to resize without problems... I also made the logo transparent so they are easier to make and can be displayed on the main screen as well as the loading screen... PNG's resize much better being lossless and all...
    david
  6. #26
    May 2005
    Conyers, GA
    Quote Originally Posted by veetid
    david
    Yes..yes..of course.. Sorry, I was a little peeved earlier today, and finding out i'd have to go through and rebuild the skin kinda itched me the wrong way.
    Though, since the last one was based off someone else's skin, maybe i'll just have to do my own thing from scratch this time. Hopefully you won't change the skins too much for the next upgrade!
    Thanks again for all the hard work, this is still, by far, the best program out there for CarPCs. (IMO)
  7. #27
    New York
    Nice, nice! Time to check it out.
    Mark
    Website: http://www.greenpowerenthusiast.com/
    Car'Puter Project
    - Xenarc 700TSV
    - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
    - 1x 256MB Corsair XMMS DDR400
    - M2-ATX
    - Belkin 802.11G W-Nic
    - Garmin 15H GPS
    - WinXP SP2 (NLited)
  8. #28
    Constant Bitrate FociMan's Avatar
    Jun 2005
    Gloucestershire
    Hoorah I can finally rebuild my install!! David yet again, you are a legend...
    Thanks...
    FociMan
    Ford Focus Collection
    EPIA M10K / 512Kb / Creative Audigy NX USB
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Bluetooth GPRS Web Connection
    Centrafuse Beta2 / MapMonkey
  9. #29
    seconded on that question with the mixer as only my front moves up and down too.. any clues?
  10. #30
    Quote Originally Posted by Skuzzle
    currently they only control the fronts... I guess they need to move the rear/center/sub the same amount... I will add this...
    david
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  3. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  4. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
  5. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
