Page 13 of 44 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 432
Thread: CENTRAFUSE BETA 2 [1.4] Requests
  1. #121
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Quote Originally Posted by veetid
    a letter every second... If it started at A and you wanted to listen to some Wilco you would have to hold the button for a really long time and listen to a computer say the alphabet...
    david
    Not if it wraps. Then it's only 5 seconds, and you can be watching the road the whole time as you hear "Number-Z-Y-X-W" (numbers should be combined, not individual digits). The worst case would be 14 seconds. At that point you just hit "Next-Artist" a few times (which I would like in Now-Playing via a hot-key as well as when under the Artists sub-category of Media Library... actually, now that I think about it, if I could just add the song to my Now Playing and have it immediately play the song, then I could just stay in Media Library all the time and I would not mind if you added any features to Now Playing or not).
  2. #122
    Apr 2005
    County Durham, UK
    I like it... it's been added to my list of things to do... I can also use the numpad for other things... options in setup that require a number will use the numpad and the same goes for when I integrate GPS... I will also use it in my phonecontrol plugin too...
    david
    ...and the sound/video too?
    Hurrah!
  3. #123
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    why not make a 3 letter search like mobile's use in their phonebook.
  4. #124
    Feb 2005
    David, I know you said you'd do PhoCo support in future versions but the problem with that is that most new BT phones will not be able to work with PhoCo since they only support point-to-point connections (only one BT connection at a time). I was wondering if you would be up to the challenge of writing your own code that connects to bluetooth phones using the handsfree profile instead of using a virtual com port like PhoCo does. The good thing about going this route is that the handsfree profile, under the audio gateway service, includes audio transfer, relaying serial commands, invoking phone based voice recognition, and phonebook management using only one connection. This, in my opinion, would give very professional results when using Centrafuse as an interface with a BT phone. Although this will take a long time to develop, I feel that if CF had this capability, it would be magnitudes better than any frontend out there.
  5. #125
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    agreed. also with going this route, you could give the option for people to use their bluetooth headsets as mic's for CF thus eliminating the previously mentioned line in/mic issue. cuz i know personally i will be going the bluetooth headset route in my carpc because it has proven to be so much easier than your all too common tethered mic.
    Your everyday carpc geek and tech guru at your service. *bow*
  6. #126
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    Mbai, great suggestion. I'm with Vchat, I would much rather use my bt headset, though having a tethered mic installed in my A pillar for when you do'nt want to hvae hte headset on would be cool too.
  7. #127
    Constant Bitrate asci01's Avatar
    Jun 2004
    Florida
    Additional cross-fading
    David,
    Would it be possible to add cross-fading when changing radio stations?
    or at least fade out the current station and fade in the new station.
    I think that would be real cool.
  8. #128
    Feb 2005
    Quote Originally Posted by asci01
    David,
    This won't be possible unless your tuner can tune to two channels at once.
  9. #129
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    or unless cf intercepts the audio from the tuner driver and does a 5 second delay
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
  10. #130
    Nov 2004
    L.A.
    That still wouldn't work, because you would lose some of that delay everytime you switch stations. You could only crossfade on the first 3 station changes LOL.
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  4. CF BETA 2 [1.3] Requests
    By camsgs3 in forum Centrafuse
    Last Post: 07-30-2005, 10:43 PM
  5. Centrafuse Launcher (Fixes Map Movement)
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-02-2005, 03:53 PM
