go to:
stat >> CONTROL PANEL >> Speech
you have to train ur voice
I installed the microsoft speech sdk 5.1 and everything works fine in that program but no responce in centrefuse.
Is there a key word to wake centrefuse or is there a program that is supposed to be running in the back ground. Also I assume that then the voice icon is yellow that means it is off right? Thanks
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
go to:
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
make sure speech is enabled in centrafuse setup... you can look in grammar.xml for all the voice commands... each command must be preceded by "computer"... so for example "computer play", "computer pause"... you can change all words, including the keyword computer, in grammar.xml...Originally Posted by inniss777
david
thanks. i will try that.
ok. I got the voice command working but 1 out of 20 commands respond correctly.
In speech properties I did the train profile for the microsoft english reconignizer. Nothing really change. So then I tried to train profile is sapi but I get an error. Is this normal?
So what do I do to get the accurace better for the voice command.
In the Sapi tutorials it responds good to my voice. Thanks.
I got everything working. Thanks.
Did you mean speech.xml?Originally Posted by veetid
B Smoov
Project Status: 90% Complete
Next Step: TIVO for Radio
Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
thats my question too!!!
I dont found the grammar.xml only the speech.xml
I changed the word computer in CF settings, at first to the word "system" and than back to "Computer" is that false??
It is crazy because I can change all words in CF speech (tha system understand me)
Than, I testet with the pusched button below rigt and then without pusching this button. I give a instruction in CF and say "computer and than for example loade home" nothing is going on!
Why?
Who know if a german sdk5.1 exist?
Because I don't found it by google :-(
And I have to speak english with my Pc by teaching it my voice (Start -> Settings -> Control Panel -> Speech -> Train Profile.)
(thats a little bit funny with my english knowledge)
and does an other hotkeys.xml exist with more keys?
be fair - be friends
welcome to the football WM 2006
Were you trying to be funny? I hope so. lol.Originally Posted by mrsony6
EDIT: Didnt realize you are German.
B Smoov
And back on topic..
Does speech.xml have to match what I speak into CF...?
Using the default speech.xml
I run CF -> Tools -> Voice Commands
Select "System Keyword"
And I say something other than computer(i.e. "Listen")
SAPI recognizes it as listen... does this change the .xml? or do I have to manually change it to match what I said?
I imagine no because this seems to work for me but I am confused as to why you would have guided us to edit the speech.xml file.
B Smoov
