Results 1 to 4 of 4
Thread: connect button
    FLAC alti's Avatar
    NY
    connect button
    I use EDGE/GPRS to connect to the internet via bluetooth.
    I have a dial up connection setup in windows to connect and if I want to connect I close centrafuse and bring up the connection and then load up centrafuse again.
    I have noticed that the old "connected" in green and "disconnected" in red in ver 1.2 have been replaced with a button that says either disconnect when you are connected and connect when you are not in ver 1.4. Currently when i press this button nothing happens regardless of whether or not i am connected. How do I set centrafuse up to use my dialup connection when I press on the "connect" in version 1.4? I checked all the XML files and the settings and did not see a way.
    By the way excellent progress on the application, I love the changes. Took more time to setup and configure the buttons to my liking, but in the end it is much cleaner and faster.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Haven't tried in 1.4, but I followed david's instructions of go into the Internet Properties in the Control Panel..
    Go to the Connections tab,
    Select the connection you want, and choose 'dial whenever a network connection is not present'. Then the connect/disconnect should work..
    Don't try to connect outside of Centrafuse, I don't know if it'll capture the online status or not..
    FLAC alti's Avatar
    NY
    Quote Originally Posted by Jahntassa
    sweet thanks, going out to the car to try it now.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    FLAC alti's Avatar
    NY
    brilliant! using the connection now, thanks!
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  1. Add a EJECT button with NCS !
    By netsuo in forum NeoCar Media Center
    Last Post: 06-08-2005, 09:20 AM
  2. 2 Commands from one button?
    By MC_Stoo in forum Road Runner
    Last Post: 05-22-2005, 06:21 AM
  3. Replies: 2
    Last Post: 04-04-2005, 04:45 PM
  4. OPUS plus power button
    By The Grinch in forum Power Supplies
    Last Post: 07-25-2004, 02:55 PM
  5. Desktop Button for standby or hibernate?
    By gospeed.racer in forum Software & Software Development
    Last Post: 04-27-2004, 03:33 PM
