Results 11 to 20 of 24
Thread: LQuickcam Embedding
  1. #11
    Newbie entr0py's Avatar
    Oct 2003
    NH
    CarCame Download Link
    I am hosting this at work so dont mess with crap! =). I dont know how long I can have it up.
    CarCam
    Let me know if you guys have any problems. I have not really tested it too much.
    VIA EPIA M1000
    Casetronic C134
    512MB, 40G Hard Drive, 8x DVD-ROM
    Xenarc 700TS ULTRABRIGHT
    Griffin Powermate
    Jeff Bipes AUX-IN for Audi's
    Opus 150W
    WinXP sp2
    myHTPC, VoiceMate Pro
    Street Atlas 2001
  2. #12
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    thanks will try it out. Is it only with usb cams or is it possible with composite (RCA) video input cams.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
  3. #13
    Oct 2003
    NH
    it is only for usb cams. how did it work for you guys?
    VIA EPIA M1000
    Casetronic C134
    Griffin Powermate
    Opus 150W
    WinXP sp2
    Street Atlas 2001
  4. #14
    Newbie crankshaft's Avatar
    Jul 2005
    Singapore - East Coast
    Hi;
    Great, thanx so much, that is EXACTLY what I was looking for. I've just downloaded it and will try it out.
    Thanx again
    PeterC
    Edit: just installed it, works great, a couple of suggestions / requests:
    1) Add the default path & filename format (i.e. yymmddnnn) to the config file, so that when you hit the caputre image button, it's a one button click without needing to select the folder / filename etc.
    2) Add the ability to invert the image in the config file (my cam is upside down)
    3) The dropdown box to select the device seems to keep focus and does not behave 'as expected' !
    Regards
    PeterC
  5. #15
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by SOS
    I hope someone hosts it :-) I like it too.
    As a programmer you can probably answer this then, is it possible to have the program record video in a cyclus? Like whenever the app is started it starts recording and saves the last XXminutes.
    Then if someone hitīs my car I can save the last XX/15 minutes recording and hit his insurance company with it
    Probably what would be better is, if it started buffering video on app startup, and you would press a button to save the past x minutes to disk.
    Can't wait to get this out to the car, thanks for sharing entr0py!
  6. #16
    Jul 2005
    Hi, Ok some more feedback...
    I just installed the webcam onto the center rear headrest pointing backwards, had a drive and what immediatly struck me when I was driving was that the image was the inverse of what I saw in the mirror, so it really needs the ability to mirror the image horizontally.
    Originally I had the camera mounted upside down but have fixed that now.
    Other potential enhancements would be to be able to set a frequency to automatically save the image for example under the same name carcam.jpg, or by using a timestamp kind of file name ?
  7. #17
    SOS
    SOS is offline
    Jan 2005
    Quote Originally Posted by tj!2k4
    Yeah, but that would require disk enough for the entire drive
    /SOS/
    XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
    Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
  8. #18
    Oct 2004
    not if it only buffered the past x minutes..
  9. #19
    Oct 2004
    @entr0py - do you have any plans of developing this app any further to include video capture?
  10. #20
    Oct 2003
    NH
    I might in the future but there has not been too much interest in it. I dont even use it in the car, i just wrote that app b/c it was pretty simple to do. I prob should work on trying to flip the image horizontally and capture video to disk, but my cheap web camera stopped working so I would need to go buy a new one. I dont really feel like spending money or time developing something which I dont plan on using.
    VIA EPIA M1000
    Casetronic C134
    Griffin Powermate
    Opus 150W
    WinXP sp2
    Street Atlas 2001
  1. Embedding BSPlayer
    By Needstorage in forum Software & Software Development
    Last Post: 01-29-2007, 03:15 AM
  2. Embedding in 1.3
    By CavityCr33p in forum Centrafuse
    Last Post: 07-18-2005, 08:16 PM
  3. Special charcter embedding problem + couple requests
    By Floatingpi in forum Centrafuse
    Last Post: 07-17-2005, 05:55 AM
  4. Replies: 0
    Last Post: 07-08-2005, 04:08 PM
  5. Embedding in Frodo player clarification?
    By firmware in forum Map Monkey
    Last Post: 05-18-2005, 01:12 PM
