What error are you receiving? Could be a problem with mapmonkey embedded in CF... Mapmonkey didn't embed in 1.2...
david
David...
Have you changed something fundamental in the code with handling COMM ports?
On CF1.2 MapMonkey works perfect when returning out of hibernation but since CF1.3 and CF1.4 this is not working anymore (GPS not found). I tried several things but all fails.
Did you do in CF1.2 some early COMM port connects or something when getting out of hibernation?
Only remedy is restarting MapMonkey or CF...
This one is breaking my head...
Anyone else this problem?
david
sorry was a bit unclear...
It embeds perfect, but only problem is the the COMM port is blocked... "GPS not found".
I think MM tries to reconnect to the comm port but the old session is still open. But strange enough this worked in the old CF release...
what type of GPS receiver? I assume non serial... serial GPS mice usually don't have any problems on resume from hibernation...
david
usb-type NMEA...
but that does not explain why it worked perfect on CF1.2 and not on CF1.4...
I'll try to look for a solution...
If anyone has the same problem (or does not have this problem) please respond.
I agree... I'm also trying to figure it out... just wanted to see what type of GPS receiver you had...
david
Same here only way i can get around it at the mo is by closing MM from its menu then close the app from CF's Menu and then restarting it all over again. hope it gets sorted soon
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
if you just hit close in the embed header in centrafuse does it not close MM?
I changed the code for closing apps in 1.4....
david
I think this pretty much is the same problem of embedded apps not receiving the windows resume from standby/hibernation event..
david
The close action as skydiver stated is a way to get MM working again.
Using the CF close button direct works too allthough I have seen this failing so that MM is still running in the process list so you can not start it anymore. But I can not re-create this action, but I have seen it 3 times since I played with CF1.3 and higher.
I think your last post is indeed the problem David.
