You can right click on the processes to end them... but with ts this isnt the easiest way I guess...
Has anyone tried this?
Occasionally, I'll have to open up taskmanager to kill off crashed applications when I'm debugging (bluetooth in particular). Since it's something I end up using fairly often, I set up taskmgr as one of the embedded applications. However, when CF embeds it, it leaves off the bottom portion of the screen, the part where the 'end process' button sits.
Obviously, using taskmanager to kill processes is a bit useless without the button, so my question is, has anyone managed to embed it properly? This problem occurs in both full and non-full screen mode.
EDIT
I just realized Microsoft locked the height of the taskmanager window. Is there any way to change that?
Carputer status: [-*---------]
Im thinking laptop...
thx for the help; my screen isn't easily accessible though, so it REALLY isn't easy for meOriginally Posted by shizzle
0l33l,
tried it, but i get the same problem... haha. Oh well, guess it won't happen.
Thx all the same fellas.
Well, there ARE replacements for taskmaneger![]()
thats what i was thinking. Maybe you will have better luck with a 3rd party application that does the same thing as the taskmanagerOriginally Posted by 0l33l
I embed taskmanager into skinbedder and then into cf, it leaves the button to terminate processes
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Send the Alt-E command.
That's exactly what I have done. I embedded Process Explorer from sysinternals.com. Works great and even gives me a lot more info on the processes.Originally Posted by antimatter
Ride: 2004 Nissan Murano SL AWD/Sheer Silver/Black Leather/factory HIDs.
MoPuter: Transflectivized Lilli 7", EPIA M-10000, 512Mb RAM, 160Gb WD, SBLive!, 54g WLAN, Holux GM-213, 160W M2-ATX PSU
Really? what kinda settings did you use for the window references in your ini file?Originally Posted by Frankino
0l33l,
Alt-E? Sorry, not sure i understand...
