Results 1 to 5 of 5
Thread: CF as Shell::Welcome Screen fix
    Constant Bitrate tangeray's Avatar
    Mar 2005
    Chino Valley, AZ (2 Hours north of Phoenix)
    Hi All,
    Newbie here. Done lots of searching and prodding about this topic. I run CF 1.4 and use the "Run as shell" command in the setup. I embedded explorer.exe into the apps section so i can view my documents and such.
    *Question: Theres lots of talk about eliminating the welcome screen which has been causing a 30 sec lag when starting up the computer. I am very new to the scripts, batch files, programming scene.
    --Can someone post EXACTLY a point by point tutorial on how to eliminate this welcome screen lag from the system when using CF as the shell. As of now, I have no problems with CF exectuing itself as the shell, so my only concern is the bootup time. Thanks in advance to any input.
    ~~Tangeray
    VENDOR - Centrafuse veetid's Avatar
    this needs to be done on my end and will be fixed in 1.5, thanks to frodo...
    david
    Mar 2005
    Thanks veetid,
    So for now, should i not run CF as a shell? Also,,,,hehe...how can i get windows back as the shell?
    when running as shell if you click exit it should launch explorer...
    david
    Mar 2005
    when i click exit...it just shows me the desktop with no icons, start menu, task bar, or lower right side notification bar. IS that normal? or did I do something wrong?
    ~Tangeray
  1. dual displays on same screen...help?
    By turbocad6 in forum Software & Software Development
    Last Post: 08-09-2005, 05:15 PM
  2. CF 1.4 skin for CF 1.2
    By superbowl in forum CF Skins
    Last Post: 08-08-2005, 04:19 AM
  3. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 06:38 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  5. Replies: 13
    Last Post: 07-02-2002, 10:54 AM
