Results 1 to 8 of 8
Thread: DVB-T & Radio - TwinhanDTV MagicBox Pro
    Jul 2005
    Rosenheim, Germany
    Can anyone tell me if this System will work with CF?
    I want watch DVB-T television & listen fm radio (radiator support??).
    here the link:
    http://www.twinhan.com/product_D%2BA_3.asp
    Thanks!
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    Has anyone got an update on this, or know where to get the SDK for this baby? I have one and want to intergrate it into vb6 if possible.....
    BjBlaster! Car MP3 & Carputer!
    bjblaster.com
    "The solution to one problem is only the beginning of another"
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I have tried DVB-T tuners before and sadly for use in the car it turned out it could never get a good signal.. I did get a signal sometimes and the picture was good but it kept flickering on / off which made it pointless. The model I tried was the USB 2.0 Freecom stick. Shame really
    CdR
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    Mine works flawlessly in the car! I have two antennas one for Digital TV and the stock car one is for FM (and analog TV). I found to to work sweet, just that the frontend I have written in VB has a hard time sendkeying the supplied apps. I want to intergrate the FM part at least into my system. The TV software is ok, because it just starts in fullscreen and works fine.
    bjblaster.com
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Hey CDR, I had the same issue with the freecom stick!
    Did you try with a different antenna or with the supplied one? I hope to have better results with a different antenna.
    Sep 2005
    Quote Originally Posted by Bj
    what hardware & antenna do you have?
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    this... http://orcboys.homedns.org/general/o...e_pc/index.htm
    (the site is still under development - I will finish it one day...)
    It's an EPIA M10000 with the Magic Box Pro. I use a 1/2 wave fibreglass whip I wound for ~800mhz. Mounted on the bullbar. (beauty of a ute I suppose )
    bjblaster.com
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Quote Originally Posted by CdRsKuLL
    CdR
    I've just set mine up and it works mint when its got at least half signal...
    I have no intentions of watching it on the move so as long as it works when stood still which it appears to do very well then I am well chuffed
    What do I have to do to both CF & RR to integrate this now? How involved is it? Or does anyone have the required files they are willing to share
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 03:34 AM
  2. CNS Maestro II now FREE / MAESTRO PRO is on the way
    By Svetoslav in forum Software & Software Development
    Last Post: 10-01-2005, 05:03 AM
  3. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  4. Replies: 0
    Last Post: 03-20-2005, 01:34 PM
  5. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 02:38 PM
