Results 1 to 4 of 4
Thread: IGuidance Embed - Sound Files Missing or Corrupted Error
    Raw Wave
    Jun 2002
    Virginia
    I'm wondering if anyone else has seen this issue.
    I have installed IGuidance and set it up as an embedded application in CF. When I launch it from within CF, however, I receive an IGuidance error message that says that "sound files are missing or corrupted, please reinstall." This keeps IG from loading. I have uninstalled and reinstalled IG with the same result. I do not get the message and IG loads fine when I load it directly (not from CF). Any ideas?
    My setup in external.xml is:
    <PATH>"C:\Program Files\iNav\iGuidance\iGuidance.exe"</PATH>
    <PARAMETERS></PARAMETERS>
    <WINDOWNAME>IGuidance</WINDOWNAME>
    <DISPLAYNAME>IGuidance</DISPLAYNAME>
    <PAUSEMUSIC>True</PAUSEMUSIC>
    <LINECONTROL>NONE</LINECONTROL>
    <MUTEONEXIT>False</MUTEONEXIT>
    <STARTFULLSCREEN>True</STARTFULLSCREEN>
    <ENABLEHEADER>False</ENABLEHEADER>
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Are you using 1.4? I believe 1.3 ran the app from the CF directory rather than the iG directory which is why you get that error. I thought that was fixed in 1.4 though. Hummm, actually, maybe you should just remove the quotes ("). I think that may fix it.
    PS: You may also want to try out SKINbedder or iGMod.
    VENDOR - Centrafuse veetid's Avatar
    yep... just lose the quotes... it is causing it to improperly set the working directory, therefore creating your error...
    david
    Raw Wave
    Jun 2002
    Virginia
    Removing the quotes did the trick. Thanks.
  1. DATABASE_Runtime Error 67 - Too many files
    By cumulus in forum FP Bug Reports
    Last Post: 05-17-2005, 05:06 AM
  2. Corrupted VS.net Files
    By BiohazrD in forum Software & Software Development
    Last Post: 11-23-2004, 05:53 PM
  3. v1.9 and asf files - no codec error
    By krissstephen in forum MediaCar
    Last Post: 03-05-2004, 05:04 AM
  4. After I copy files, they are corrupted.
    By Cliff in forum Software & Software Development
    Last Post: 05-17-2003, 09:49 PM
  5. test sound files?
    By poolguy in forum General MP3Car Discussion
    Last Post: 01-04-2002, 04:15 PM
