Results 1 to 10 of 11
Thread: Play DVDs stored on hard drive
    Aug 2005
    Canada
    is there a way to play DVDs that are stored on the hard disk with the integrated DVD player in CF 1.4?
    The only I found was to put a movie's directory on the root of the C drive and rename it to VIDEO_TS so that CF loads it
    my movies are stored in C:\Movies\movie_name, with no VIDEO_TS folder
    the "playlist" button in the DVD player doesn't get me anywhere
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Why not try using AutoGK (www.autogk.net) to re-encode them to XviD or similar?
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Feb 2005
    Quote Originally Posted by WaRFiElD
    This is how most DVD applications work...they'll play the files as a DVD Video disc if they are stored in a Video_TS folder.
    Jun 2005
    Brisbane
    I wrote an app that lets you toggle the current dvd. Basically it just moves the dvd you select to the C:\Video_TS folder. When you select another DVD, it moves the files back to where they came from. It has the blue ice look also. If your interested in giving it a go, let me know.
    Aug 2003
    Warwickshire, UK
    Why don't you set it up as C:\MovieName\Video_TS ? That works for me in PowerDVD.
    I still say just re-encode to XviD, then you can fit more on your drive.
    Jun 2005
    Brisbane
    Aren't we talking in the Centrafuse thread?
    The land of polar bears and nekkid blonds
    Quote Originally Posted by jasonk
    According to the "navigation bar" we are...
    "MP3Car.com Forums > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > Play DVDs stored on hard drive"
    As for the problem, I'd do what Stevieg says, encode it to xvid.
    Unless you're using a +20" you don't need the resolution of a DVD.
    If encoding still isn't your cup of tea, then make an image(bin/iso) of the DVD(files) and then mount it in DaemonTools.
    Centrafuse will see it as an ordinary dvd-disc and it'll play just fine.
    DaemonTools do support command line mounting of image-files so you wouldn't need to copy any files like JasonK is doing.
    daemon.exe -mount 0,"c:\My Images\nameofimage.cue".
    /M
    Aug 2005
    Canada
    Good idea Maximus, didn't think of that
    As for re-encoding to Xvid, I've got a 160Gb Hard-disk in-car, so space isn't my main concern. Plus I really hate MPEG4, but thanks anyway for the suggestion
    I still think it would be a good thing to be able to browse DVD files in hard disk, as PowerDVD and others do
    Keep up the good work guys, CF is really the most professionnally built front end to date!
    VENDOR - Centrafuse veetid's Avatar
    that "playlist" button simply should take you to the DVD menu, if it has one... I don't currently support playing DVD's from the HD.. using daemon tools it the best solution for now...
    david
    May 2003
    You may want to check out this:
    http://ratdvd.ca/
    It compresses the whole DVD, menus included, into a single playable file.
  1. Hard drive vibration/shock solution? NoiseControl No Vibes
    By slushieken in forum General Hardware Discussion
    Last Post: 08-13-2005, 07:19 AM
  2. Stop Press: Faulty Hard Drive Fails to Work
    By phatbenny in forum General Hardware Discussion
    Last Post: 12-23-2004, 05:36 PM
  3. Ultimate Hard Drive Mount or bad idea?
    By rockthevolvo in forum General Hardware Discussion
    Last Post: 08-29-2004, 04:22 PM
  4. Problems with EBAy kiosk and hard drive?
    By davcd3 in forum General Hardware Discussion
    Last Post: 08-12-2004, 04:08 PM
  5. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 08:07 PM
