Tip for those using CF 1.4 and constantly switch between MUSIC and GPS
I found it annoying that if I had the GPS window open in fullscreen mode, the only way to jump to the Music section was to Hit 'HOME' and then hit 'MEDIA'.
The solution I was looking for, was to have the MEDIA button at the very top left, in the place where the HOME button is located. :)
Doing it is not too easy... you actually have to go the the skin file, and swap the entries for <BUTTONS>/<HOMEPAGE> for any of the <BUTTONS>/<MAIN1>...<MAIN5> entries. (I chose to put the HOME button at the very bottom, so I swapped it with the <MAIN5>
Sorry if this is confusing... but if you've played around with the XML files, you know what all this means.
A request for Dave: Could you allow the assignment of the large 'HOME' button the same way you assign the 'MAIN' buttons? (i.e., in the Buttonactions.xml file). This way, it would be very simple to configure the use of that button, with the MEDIA button, or whatever other action folks want to permanently have at the top.
