Results 1 to 5 of 5
Thread: Iguidance + CF on top not embedded but not fullscreen
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    Cool Iguidance + CF on top not embedded but not fullscreen
    I want the iguidance using skinbedder to overlay cf like this so I can get to the control buttons still and then I am also still able to get back to "HOME" to get back to the menus.
    It needs to come down a little thats easy with a top setting. How do I set the embedd container to a larger size that might do it also. The stock embedd container is too small + including the skinbedder buttons so I want to use the full width.
    Wide Skinbedder(skinbetter) window
    What I am trying to acomplish but down a bit(top=..)
    The reason it sort works there is becuase there was a window called "skinbedder" open so it took that in the background and then showed skinbedder. It only sorta works like this the first load but then I can't get back to it.
    thanks
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    Mar 2004
    SOCAL
    Found it there its skin specific as it should be. I thought it might be something different etheir way problem solved.
    Working Correctly, I cut it close to overlapping still just to make sure i don't press the other buttons instead of menu on the iguidance window.
    Aug 2005
    Jersey
    i know this is a little off topic, but how did you make those buttons on the left??
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hey that skin looks pritty damn clean n e possible way u can email me the files? djxklusive at gmail dot com
    Poe
    Poe is offline
    Oct 2005
    i'd also like it if you don't mind. poe408@gmail.com
    thanks!
  1. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 06:21 PM
  2. XP Embedded to CF
    By Cheekz185 in forum WinNT Based
    Last Post: 05-04-2005, 02:01 AM
  3. Screen size of IGuidance Embedded in FP
    By PDiddy in forum FrodoPlayer
    Last Post: 02-11-2005, 07:07 PM
  4. GPS_ iGuidance embedded fails on first try
    By phord in forum FP Bug Reports
    Last Post: 12-19-2004, 12:51 PM
  5. Embedded iGuidance Window Size?
    By All4Sky in forum MediaCar
    Last Post: 08-27-2004, 08:00 AM
