Results 1 to 8 of 8
Thread: Error trying to run Centrafuse 1.4 after install
    Oct 2005
    i have tried numerous times to run Cnetrafuse 1.4 after installing and i get the following error. I have removed and re-installed .NET and have run all the updates to it and still i get the same error. I have not messed with .NET so i have no idea what the error message is trying to say.
    Progress
    [===== . . . . . ] 50%
    Just need a touch screen and most importantly... A car
    Jan 2003
    Ruston, LA
    Looks like you disabled performance counters.
    That breaks some stuff.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Oct 2005
    unsure what that means or how to enable preformance counters. The only thing that i know i have disables running WinXP Pro is most of the options in the preformance setting from the system menu which i have tried enabling them all and i still get the same error
    Progress
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Have a look here:
    CF Won't Start
    Look at fisrt post and 7th post.
    But it seems that is not same problem as your.
    It seems that it hasn't work for other but it has worked for me
    Hopping it will help!
    !!!!!ATTENTION!!!!!!
    I am not responsible of any thing. Make a backup before do anything
    VENDOR - Centrafuse veetid's Avatar
    1.5 does not use performance counters anymore...
    david
    Apr 2005
    I had the same problem. Couldn't figure it out. Centrafuse would not run on my desktop because of that error. Worked fine in my car though.
    I had recently bought a new motherboard and had to reinstall windows. Centrafuse works fine on my desktop now. I'm not sure you would want to go that route to get Centrafuse working, but I couldn't come up with a solution to it.
    Oct 2005
    i tried changing that Reg info and still have the same problem =(, I think i will just wait for 1.5 to come out. Hopefully soon.
    Progress
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  3. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  4. 94 Jeep Grand Cherokee Install
    By jamiewhittingha in forum Show off your project
    Last Post: 08-02-2006, 02:02 PM
  5. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
