Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 53
Thread: 1.5 GPS Screenshots
  1. #41
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by snicka
    looking to pick up destinator to go with 1.5 when it comes out but I can only find Destinator PN and really only want the most updated maps since my experience with Destinator 3 maps has been poor. Will centrafuse work with the PN maps, I have searched and seen a bunch of concern about it and mapmonkey but no actual answer.
    I will be working with PN once the PN SDK is finished around march most likely... The first release of Centrafuse will use Destinator 3.1... You will be able to get Centrafuse bundled with the needed Destinator 3.1 maps...
    unless they get PN finished in time and I will convert over... there will be an upgrade to PN either way...
    david
  2. #42
    Jun 2005
    Phoenix, AZ
    Quote Originally Posted by veetid
    It actually already does pause, not just lower the volume...
    david
    David,
    Would it be possible to have this feature configurable?
    Option1= Have music/video pause when Nav has an alert.
    Option2= Have music/video lower in volume when Nav has an alert.
    Option2 may not work well on some systems depending on their setup/preference. For it to work best, I would imagine having the GPS alert sound at the current volume level, while the music/video be lowered by a preset percentage (should this be configurable as well?).
    What do you think?
    Scott
    EDIT:
    Also, if one has the music playing very loud it would be nice if the computer knew that so it would not play the Nav promp too loud. I'm not sure how desirable this feature would be without trying it out, but it may be worth a thought. Also, if this were implemented, it would not be compatible with setups using a headunit for amplification.
    Alernatively, GPS promps could be played at a preset volume level (this is how it works in my father's Acura). But again, this would not really work if you use your headunit for volume control.
    Scott
  3. #43
    Jun 2005
    Phoenix, AZ
    David, any comment on my above post. I would much rather have music lower than pause.
    Scott
  4. #44
    Newbie Kostas GOLF V's Avatar
    Feb 2005
    How can i add a map in centrafuse 1.5???
  5. #45
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    Quote Originally Posted by spdyscotty
    Scott
    pause is way better then just lower the music don't do that!
    make it a option to make both people happy...
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  6. #46
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Optional is best. I would definatly prefer a quick fade to low-volume with GPS audio "overlayed" and then a medium fade-up to restored volume.
  7. #47
    Jul 2004
    Quote Originally Posted by mbkowns
    Looks like destinator which I thought the dll expired. I got that sdk one that you buy and it expired when I got it. So instead I used Skinbedder and found a skin for it. I hope I am wrong about the above becuase I like how it looks.
    Now here is what I have(I have since change the colors to black and white on the background.)
    Is that iguidance running embedded? How did you get the top menu removed.
    2003 Black Impala
  8. #48
    Mar 2004
    SOCAL
    yes thats IG what I just played with the window container sizes in the xml file to make it look like i wanted. I have basicly put doing anything else with IG off because of whats to come with D5 and D6 in the future.
  9. #49
    Nov 2004
    L.A.
    D5 & D6? I'm not impressed. iGuidance is way better than destinator and I doubt D5/6 will change my mind about that. In any case, both suck compared to Google Earth. As soon as we have a touch-screen interface to enter addresses and all, that will pretty much render all other Nav solutions garbage.
  10. #50
    Constant Bitrate OoNikFraleyoO's Avatar
    Mar 2005
    Alabama
    For you maybe, you live in L.A. Take a look at Alabama on google earth. I don't want that ***** on my screen. As far as d5/6, I'm may just buy it and see. Worst case is, I'm out some money and have 2 nav solutions in the car instead of one.
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  2. Replies: 6
    Last Post: 02-04-2006, 10:22 AM
  3. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  4. Replies: 8
    Last Post: 03-26-2005, 11:29 AM
  5. Replies: 9
    Last Post: 10-25-2004, 02:34 AM
