Page 3 of 10 FirstFirst 12345678910 LastLast
Results 21 to 30 of 96
Thread: New Release Centrafuse 1.5
  1. #21
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by RoyN
    david, any idea about my problem above?
    It doesn't like something you are putting into one of the settings fields... most likely a non valid XML character...
    david
  2. #22
    FLAC alti's Avatar
    NY
    everyting looks awesome, the plugins and control of the buttons from within the program are great! one question before i install this in the car. can i still use iguidance? I dont see how in the settings?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  3. #23
    FLAC alti's Avatar
    NY
    just bring it in as an external app?
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  4. #24
    Quote Originally Posted by defsquad
    David,
    COuld you explain this:
    "improved volume control in the lower range by using a logarithmic method"
    The volume percentage is around 80-95% when it should read more like 25-35%. The volume slider in the windows control panel shows more like 25-35% as well.
    Curious if anyone else has this lil anomaly. Outside of that minor annoyance, i LOVE 1.5. You seemed to have sped it up a bit too from this mornings accidental release .
    Thanks as always for ALL of yours and your designers hard work, it is well received and appreciated.
    It's logarithmic volume control... it gives much better controll than the windows linear one... move the slider around the bottom in windows and see how much the volume changes... then move the slider in the top range and notice there is pretty much no change... I now change the volume based on decibels, like professional audio equipment....
    iTunes implemented it in their latest version... don't compare based on looking at the windows slider, which is linear and wrong for audio, but listen with your ears... you will notice that it's a perfect audible transition all the way up the scale now...
    david
  5. #25
    FLAC alti's Avatar
    NY
    and one other question, sorry, is there a way to go back to pressing on the top bar making the external app full size? instead of bring up the media window?
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  6. #26
    Quote Originally Posted by alti
    you can add as many external applications as you want now... just use the GUI in tools... Go to Ext Apps and click the + sign, name it, and select it... You will get all the options... You can then use "Button Actions" to assign it anywhere you want...
    You no longer should ever edit a file manually...
    david
  7. #27
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    David.
    You make that volume thing sound soo rad, so therefore I shall follow and use it like you intended
    thanks!
  8. #28
    FLAC alti's Avatar
    NY
    nevermind i see now that if you press on the blank area to the right of the keyboard it works! Is it supposed to be blank? i noticed that the integrated apps have an icon
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  9. #29
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by veetid
    david
    Ok so at min volule it should show 30%? since at 0 it shows 30%...
    Also is 180MB memory normall ammount?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  10. #30
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Good job on the release
    Was getting worried we would have to wait a while
    Is there going to be some documentation on writing plugins?
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 04:18 AM
  3. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  4. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  5. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
