Frankino: check your confi and ini files. It's somewhere in there, just delete it.
david, I locked the screen and well
forgotten che keycode
is there a way to fix?![]()
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Can a feature be added to that when I open up the media browse dialog it directly goes to a specified directory? I never catalog my music into the library, I always use the directory browse feature, but I hate having to drill down 3 menu layers to get there (made worse in CF 1.5 via an extra layer of indirection - the multiple music paths feature).
I have search hours but not find.
In 1.4, when windows started, CF started jsut after automaticaly (I precise that I wasn't in shell mode).
How must I do?
If I'm understanding you correctly, you can add a CF shortcut to your startup folder.
Is there any way to add the ability to display track information on two lines, rather than one?
Current display:
Artist - Title
Desired display:
Title
Artist.
This would result in fewer songs being scrolled. Just a thought.
The naming convention is still not right in this version
Artists beginning with 'The' should not be sorted as a T
I also noticed a bug in that screenshot
At the top it should say Page 18/21 but the 1 is cutoff
No,Originally Posted by dragonjo8
Just want CF to start automatically when windows start, like did 1.4
hello coucouillu
Whree did you buy your tft VGA usb display???
And how mutch did this cost?
does a update exist from CF 1.5??? because 1.5 have many problems
