David said, talking about ability to remove header from embedded apps...THANK YOU. Precious space wasted there in some instances!!!!Originally Posted by veetid
that will never happen....
I can always post an LIC file to make the application continue to work, like I did with 1.4...
note: all this licensing is not in the BETA's to keep people from using them... it's for me to BETA test the licensing system... I started with emailing those lic files, that was a bad idea... I now know that I must uninstall the directory completly or new version will have problems with old ones... it's all just for BETA testing....
again guys... I appreciate all the BETA testing!!! A promotional code will be emailed to all registered users when the commercial version comes out....
david
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
I asked this for last version but I would still really like a function to play a random album from the library
Another thing Id like to do is disable the CD and USB support. The icons are clutter and unnecessary when you dont use these things (also saves resources and the possibility of accidentally clicking on them)
That is great thanks!!Originally Posted by veetid
www.superchargedmiata.net - all about roadster lifestyle
tried to embed G-Force but it always embeds off center.
Got the old Geiss.scr and embedded but is there any way we can force it into the CF window (like in 1.2) as it always takes over the screen!?
I dd some testing the last days..
1) volume increase is far too slow in my opinion, it should accelerate when you keep it presser (like 1.4 did)
2) the apps embedding area in 1.5 default skin is a little small, I fixed it manually but it was a pain in the ***, took me two hours (ok I'm lazy)
I also noticed this rel is a bit slower than 1.4 and I also got the green buttons problem (and the keyboard-fullscreen buttons messed up in 800*600)
by the way this app is really going to be amazing, my god I screamed when I saw that USB device button which loaded my usb pen and started playing it! great job David, I sense there is a LOT of work ahead but it's going to be THE carpc killer application![]()
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
hello did here somone know where I get german file's vor CF 1.5
Works the key for 1.5 in 1.4???
Because then i install 1.4 bcause i found german fils for CF 1.4
Whre can I get 1.4??
Best reguards
Suggestion for External App Configuration:
Include a Set Action field in the External App configuration section for quicker configuration..
You can't yetOriginally Posted by mrsony6
Probably not.Originally Posted by mrsony6
There's probably a reason you can't get it, which means you shouldn't.Originally Posted by mrsony6
It should be understood that we're BETA TESTING Centrafuse.. we're supposed to be helping find the bugs in the latest version.
ok thankst
Than I install 1.5 and post my Problems where
but my in english isn't very good!!!
