It's just for testing purposes... I will be reselling Centrafuse with Destinator once it's completed....
david
How do I go about getting a new map for Destinator?
The map it has looks like its in Germany right now...
david
if you have maps already, then u can put them in the destinator map and switch map in CF 1.5Originally Posted by solodesignz
David how can i temp. remove the destinator plug-in?
I would like to use mapmonkey, since it has more features at the moment.
www.superchargedmiata.net - all about roadster lifestyle
What are you missing in the integrated destinator ?
- Superbowl
i never drink water cos fish ***** in it. (w.c. fields)
for instance the speedcams, and the option to change the language.Originally Posted by superbowl
you can remove the desintator plugin by clicking "plugins" in tools, highlight GPS, and click "-"... It does not permanently delete the plugin, but moves it to inactive plugins, which you can add back later with "+"...
david
So when you package Destinator into Centrafuse - will it mute the music playing when it has an audio direction to give? That to me is the holy grail for frontend/navigation integration.
Originally Posted by veetid
Hi David..
This don't work for me..
Breake down:
I remove the GPS pluggin. Works fine.
Adds MapMonkey. Work fine.
But next time I restart CF it automatictly reinstalls the GPS plugin.
Any ideas why? Is it possible too completely remove the plugin? I've tried to remove the Destinator folders in plugins and pluginsinactive. Still the same. Reinstalls.
King
I found a way aroud it. I deleted the destinator.dll. and made a blank txt file and renamed it destinator.dll
Guess CF requires that .dll file..
