Results 1 to 10 of 13
Thread: Map Monkey+CF1.5
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    Map Monkey+CF1.5
    did somebody get this to work already?
    I keep on getting errors...
    I have as windowname "Map Monkey - [GPS]"
    www.superchargedmiata.net - all about roadster lifestyle
    May 2005
    ok figured out why it is not working...
    CF 1.5 Starts up destanator. this is wy mapmonkey is not working...
    Is there a way tho remove the plugin until there is a version of the plugin with more features?
    Otherwise i am forced to use CF1.4...
    Sep 2005
    Exactly what he said ^^
    Sep 2002
    New Jersey
    Tools -> Plugins -> Highlight GPS and hit the - I think removes it?
    1991 Camaro Z28
    2004 Acura TL
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by SLAYER6669
    yes... this will remove it... you can add it back later with "+" and it will be in inactive plugins folder...
    david
    May 2005
    but when i do this, cf still starts a part of destinator, and i still can't start mapmonkey..
    map monkey works fine without cf loaded..
    And no other nav program works.... (just for info, i reinstalled my system before i installed cf)
    Quote Originally Posted by lazy_g
    Make sure there is no Destinator folder in the plugins folder... move it to the inactive plugins folder manually, which is what "-" should have done... then it will not load destinator...
    david
    May 2005
    ok the problem is not that it does'n't move it to the inactive map... That it does.
    But on my laptop (different system) it wil always repair cf and reinstall the plugin!!
    May 2005
    is there anybody how has the same problem?
    Is there a way to install CF without the plugin?
    Because now i really am forced to go back to cf 1.4 since i can't get navigation to work..
    May 2005
    well i just went for a test drive withe the integrated GPS, i actually like it!
    accept it is in Yards end miles, and i would like it in KM and meters... is it possible to change this?
    The features that i am really missing are:
    - Home button
    - Speedcam database
    - Language change (but for now just install mapmonkey and change voice to any language, the integrated gps will take this setting... )
    - Speed on the screen.
    - make it start in 3d mode instead of 2d.
    But back ontopic, i still cannot remove the plugin...
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Replies: 106
    Last Post: 10-20-2008, 10:09 AM
  3. Few Questions About Map Monkey and Destinator
    By Yevgeny in forum Map Monkey
    Last Post: 08-10-2005, 06:00 PM
  4. Replies: 3
    Last Post: 02-03-2005, 01:11 PM
