OK, I'm getting pretty ****ed at this point cause I can't get either version to work, so I figured I'd post for some help.
I originally had Centrafuse 1.4 installed and it worked great with my serial code, no problems.
I wanted to try out the new Centrafuse and heard that you need to uninstall all previous versions. I uninstalled CF 1.4, deleted any remaining folders off my C drive, then installed CF 1.5
Using the new Serial Key from CF's website for 1.5, I was able to install and unlock the new version. The new version worked (bugs and all) without problems.
Well, I was getting a little fed up with all the bugs in the new version and figured I would go back to 1.4 and use that. So, I tried reversing the process. I uninstalled CF 1.5, deleted the remaining folders off my hard drive that it left, and reinstalled 1.4
Once I run CF 1.4 now, it says that the trial has expired. I never get the screen saying that there's the trial period. So on the screen below I entered my original 1.4 Serial Key and nothing happens. It goes back to the same screen as below, just saying that the trial has expired.
Screenshot:
To fix this issue, I tried uninstalling CF 1.4, removed any folders, then proceeded to try to delete any related registry entries. I'm not too familiar with deleting reg keys, but I went into regedit and did a find for all entries with the name "centrafuse". After deleting everything found, I searched again for anything named "flux".
I reinstalled 1.4, and the same thing happens. I'm so frustrated and have spent a couple hours messing around with this, that I apologize if there's already a posted solution to something like this.
Any suggestions. Is there a specific reg key I'm missing that housing the license info or something?
