Results 1 to 7 of 7
Thread: What XM Prog to use with CF
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    Whats the best program to use with CF For XM. I dont see any program built in so which intergrates the best in CF 1.5
    CENTRAFUSE From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
    Constant Bitrate Prindle19's Avatar
    Dec 2004
    Jersey/Virginia Tech
    don't bother. no XM program works after hibernation when tied to centrafuse....waiting for an xm plugin
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Prindle19
    I now manually send the proper resume from standby command to embedded external applications... you should try again in 1.5...
    david
    Oct 2005
    Which program is best to use then?
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by VitalRyan
    ExtremePCR embeds pretty well, but is not touchscreen friendly.
    Your best bet is probably Frodo's satellite program. Check out this thread:
    *Release*[SAT RADIO] Alpha 3
    You will need to go to frodoplayer.com to get the program as the link posted in the thread is dead.
    There is a good Centrafuse skin for Frodo's program in post 16 here:
    Frodo Satelite Radio X
    As others have said, the problem is that the XMPCR does not play nice with hibernation.
    Raw Wave
    Jun 2002
    Virginia
    David,
    I know you now have an XMPCR unit to play with. Have you had any luck getting it out of hibernation or have you been too busy on more pressing issues to mess with it?
    Raw Wave
    Jun 2002
    Virginia
    I just tried to resume FrodoSatRadio from hibernation while embedded in CF1.5 and could not make it work. After resuming when switching to XM everything locked up to the point that I needed to reboot.
    I should note that when I had XM running prior to hibernating the sound quality was unacceptably flat. XMPCR is known for bad sound quality and because it has to use line-in to avoid conflicting with the wav being used by CF, there is no way to improve the sound. I hope whoever winds up designing the XM plug figures out a way to utilize wav so we can improve the sound quality.
  1. Possible to split XM Direct cable to computer and XM commander?
    By Jemmi in forum General Hardware Discussion
    Last Post: 12-14-2005, 03:07 PM
  2. Replies: 2
    Last Post: 04-27-2005, 02:07 PM
  3. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  4. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
