Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: What Radio it the best for CF
  1. #11
    VENDOR - Centrafuse veetid's Avatar
    It works fine... The RadioXtreme has a mono mini jack plug for antenna in... All you do is get a car antenna extension cable and cut one end off... Then go to radio shack and crimp on a coax connector... Then use a coax to 1/8 mini phono adapter and plug right into the RadioXtreme... works like a charm...
    The RadioXtreme plug is properly grounded, unlike the worthless dlink people try to use...
    david
  2. #12
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Hybernation & standby
    David: how does it react to hybernetion & standby. If it was playing and you place the system into hybernation, will it resume playing wants the system comes out of hybernation.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
  3. #13
    Quote Originally Posted by inniss777
    works fine... yes it keeps playing out of hibernation... I have never had a problem with that except when using radiator with certain hardware...
    I plan to phase radiator out... just add direct support for most popular radio's and make sure they work or get reset when needed out of hibernation...
    david
  4. #14
    Apr 2005
    Toronto, Ontario
    Quote Originally Posted by veetid
    David, would this method work with the Radioshark? It has a mini jack plug, but I'm not sure if it would work.
    Basically I got a car antenna extension cable, cut off an end, and soldered it directly to a miniplug connector, which did absolutely nothing.
    Any help is greatly appreciated.
    I know that getting Radioshark to play along is not ideal, but it's the only thing that will do AM.
    '03 Intensa Blue Pearl Lexus IS300
    Specs: Xenarc 700TS, Opus 150W PSU, CarCPU Case, 2.0 GHz Celeron D, DFI PS-35-BL, SB Audigy2 NX, Centrafuse 1.4
    Progress: Car PC up and running!
    To Do: Navigation, WiFi, AM/FM Radio, DVD
  5. #15
    Quote Originally Posted by azzurro
    it should... might have messed up the ground when you soldered... since antenna extension cables are coax, you can easily attach a regular coax connector, the style for cable TV... you have to know how to properly put those on too... spread the wire around and down before you slide on and crimp for ground... make sure you know how to attach with a coax crimper...
    then just get a coax to mono mini plug adapter...
    david
  6. #16
    Apr 2005
    Toronto, Ontario
    david
    Thank you David!
    So can I use something like this with this, and then connect it to this?
  7. #17
    Thank you David!
    yep... they even make F connectors that are twist on so you don't have to buy the crimper... Getting a good connection with the F connector is crucial... if you don't properly connect it and get good ground, it will not work... google on how to properly connect connectors to coax...
    david
  8. #18
    Nov 2004
    radioextreme for centrafuse
    can i use the pci version instead of the usb one?
  9. #19
    Quote Originally Posted by sajeev
    not sure.... never tried... probably would work...
    david
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 03:34 AM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  3. Replies: 0
    Last Post: 03-20-2005, 01:34 PM
  4. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 10:52 PM
  5. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 02:38 PM
