Results 1 to 10 of 19
Thread: What Radio it the best for CF
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    What Radio is the best for CF. Also where do you get radiator? TY for the help!!
    CENTRAFUSE From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
    Aug 2004
    Black Hills, SD
    Well Centrafuse works with radio xtreme you don't even need radiator for it to work. Its plug and play so you also don't need to worry about drivers. Probably the easiest solution to go with. Here is the link you can get it from.
    http://www.radio-xtreme.com/
    Hardware: VIA Epia MS 12000, 512 DDR, 60GB HD, 7" Xenarc, GM-210, Wi-Fi, Bluetooth, Radio Xtreme
    Software: Centrafuse2, Phonecontrol.net, nLite, TopoUSA 5.0, iGuidance, Girder, Winc
    Constant Bitrate 2 STanGeR's Avatar
    Aug 2005
    Terre Haute, IN
    Is that website reliable? Meaning can I trust ordering it from there, or is there somebody in the US that sells them?
    Aug 2004
    Black Hills, SD
    They are reliable, I ordered from there and I got it. Didn't take as long as I thought it would. It does go through customs so it does cost a little extra for shipping. I think it took me about a week or 2 to get it.
    Aug 2005
    Terre Haute, IN
    Sweet, I will get one ordered pronto!
    Nov 2004
    Russellville, AR
    It looks neet but i dont need a remote and im looking for something to tie into my cars Ant. for a better signal any other good radios I can get.
    Aug 2004
    Black Hills, SD
    I don't use the remote either not that it would do much good its stuck behind the dash where a ir signal wouldn't reach. You can tie into the cars antenna with that unit, the radio has plugins for ant. in, audio out, and usb. Like all usb radio solutions you have to tie into a line-in on your sound card.
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Just FYI:
    1) "You may connect the dipole antenna to the “Antenna-In”, spread the antenna to a T-like shape for best reception." -Doesn't sound like it would work with a normal car ANT.
    2) You do have to connect the audio out to the sound cards line-in. Lame! This is not the case with the Griffin RadioShark USB.
    Quote Originally Posted by Floatingpi
    This is not true!
    Aug 2005
    Terre Haute, IN
    I am sure that you can use an adapter to connect the antenna to the stock car antenna.
    Nov 2004
    L.A.
    Sure you could attach the wires, but I believe the antenna technology is different and would therefore not give you the best reception. This device wants a "dipole" antenna (like those dual-row, plastic-covered, flexible wires that making a big "T"). I do not think a normal car antenna is a dipole antenna. A wire of any type may help reception, but for the best reception I would think you would need a tuner that had a connection meant for the type of antenna technology used in car antennas (one wire shielded by the other with a certain impedance between them). On the other hand, I don't know much about antennas, so I could be completely wrong... I tried to Google for some info but did not turn up much.
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 02:58 PM
  3. Replies: 0
    Last Post: 03-20-2005, 02:34 PM
  4. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 11:52 PM
  5. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 03:38 PM
