YOU NEED .NET 1.1 for the Converter
Tested with iTunes 6.0.1.3 - Let me know if it doesnt work.
I couldnt work out how to properly make Centrafuse playlists, so i wrote this to convert my iTunes playlists to Centrafuse playlists.
Usage:
Right click on your Playlist in iTunes, and select Export. Export the file to XML format.
Run convert.exe with your file that your exported.
Eg: convert.exe myplaylist.xml
this will produce myplaylist.mpl which you can insert in your Centrafuse playlist folder. (C:\Program Files\Flux Media\Centrafuse\playlists)
I've included the code so you can see it contains no viruses :P
I hope its useful, it was made just for me, so ignore the quirks
Code:
using System;
using System.Xml;
using System.Collections;
using System.Reflection;
using System.IO;
namespace iTunesPlaylistTOCentrafuse
class Class1
/// <summary>
/// The main entry point for the application.
/// </summary>
[STAThread]
static void Main(string[] args)
Console.WriteLine("----------------------------------------");
Console.WriteLine("iTunes to Centrafuse Playlist Converter.");
Console.WriteLine("(C) Konnichiwa (JCarter) 2005");
Console.WriteLine(string.Empty);
if(args.Length != 1 || args[0] == "/?")
Console.WriteLine("Usage: convert.exe InputFilename [inputfile.xml]");
return;
Console.WriteLine("Opening iTunes Playlist...");
string inputFilename = args[0];
XmlTextReader reader = new XmlTextReader(inputFilename);
ArrayList songList = new ArrayList();
Console.WriteLine("Reading songs...");
try
while(reader.Read())
XmlNodeType t = reader.NodeType;
if(reader.NodeType == XmlNodeType.Text)
if(reader.Value == "Track ID")
songList.Add(ExtractSong(reader));
else if(reader.Value == "Playlists")
break;
catch
Console.WriteLine("Failed reading iTunes playlist.");
return;
Console.WriteLine("Read {0} songs.", songList.Count);
string outputFilename = System.IO.Path.GetFileNameWithoutExtension(inputFilename);
outputFilename += ".mpl";
Console.WriteLine("Writing songs...");
try
using(FileStream writer = new FileStream(outputFilename, FileMode.Create))
writer.WriteByte(0xFF);
writer.WriteByte(0xFE);
for(int i = 0; i < songList.Count; i++)
Song song = (Song)songList[i];
string location = song.Location;
location = location.Replace("%20", " ");
location = location.Replace("file://localhost/", "");
string line = song.Artist + " - " + song.Name + "|" + location;
byte[] unicodeLine = System.Text.UnicodeEncoding.Unicode.GetBytes(line);
writer.Write(unicodeLine, 0, unicodeLine.Length);
if(i != songList.Count - 1)
byte[] returnChars = System.Text.UnicodeEncoding.Unicode.GetBytes("\r\n");
writer.Write(returnChars, 0, returnChars.Length);
catch
Console.WriteLine("Failed writing Centrafuse playlist.");
return;
Console.WriteLine("Wrote {0} songs.", songList.Count);
Console.WriteLine("Finished.");
private static Song ExtractSong(XmlTextReader reader)
FieldInfo[] fieldInfo = typeof(Song).GetFields();
Song song = new Song();
if(reader.NodeType == XmlNodeType.EndElement)
if(reader.Name == "dict")
Console.WriteLine("Read: " + song.Artist + " - " + song.Name);
return song;
string key = reader.Value.Replace(" ", "");
Skip(reader);
string val = reader.Value;
for(int i = 0; i < fieldInfo.Length; i++)
if(fieldInfo[i].Name == key)
fieldInfo[i].SetValue(song, val);
break;
return song;
private static void Skip(XmlTextReader reader)
reader.Read();
reader.Read();
reader.Read();
private class Song
public string TrackID;
public string Name;
public string Artist;
public string Album;
public string Genre;
public string Kind;
public string Size;
public string TotalTime;
public string TrackNumber;
public string TrackCount;
public string Year;
public string DateModified;
public string DateAdded;
public string BitRate;
public string SampleRate;
public string Season;
public string PersistentID;
public string TrackType;
public string Location;
public string FileFolderCount;
public string LibraryFolderCount;
