I disagree. GammaControl only requires you to configure the settings once, and then you never touch it again. I mean, NEVER.Originally Posted by lifeboat
GammaControl is a powerful and useful utility but IMO it takes a bit too much configuration and "on the fly" adjustments while driving would seem difficult. The main benefit I see with the overlay idea is that there need only be two controls, color and transparency level.
IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Depends on what you want... I'm not dogging GC, but personally I would like to be able to switch between different tints (red and black), and adjust levels quickly & easily for varying conditions i.e. twilight through darkness, transition from rural darkness to city limits, etc.Originally Posted by justintime
I could use GC for this if the GUI was changed, maybe using sliders to change values instead of buttons, and the ability to link values so they adjust together. Extra presets would help too.
Oh, I see. I can't imagine using it that way. But to each his own!![]()
2002 Honda CR-V
EDIT: please see autodimming solution here:
http://www.mp3car.com/vbulletin/software-and-software-development/67844-autodimming-monitor-after-2-seconds-of-inactivity-solution-inside.html#post723558
2002 Honda CR-V
Following a link from the other thread mentioned above, there is a Widget that does almost exctly what I wanted:
http://widgets.yahoo.com/gallery/?search=tint&x=0&y=0
The Tint Screen Widget. Cost about 5MB of RAM and the CPU load is almost nothing...
