Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: TMC support in CF, how will you solve it ?
    The land of polar bears and nekkid blonds
    Hello David,
    I met with JC60 today at the show and we where discussing different aspects about Centrafuse, Racemiers radio and GPS.
    I assume you will have native support for Racemiers radio since it's the best and more or less _only_ solution for in-car radio.
    But how will you solve the TMC bit for Destinator ?
    Do we have to use a TMC/GPS reciever like the GNS unit, or will you extract the TMC-data from the radio and merge that with the GPS data from any NMEA compatible unit (UBlox for example) ?
    If option 2 (extracting TMC/RDS data from the radio) then please make it so that it is possible to use two modules, because only a few radio stations transmit TMC data and in most cases it is not the ones you'd regulary listen two. If you make it so that it supports two modules, then there's also the possibility of using the second module for alternate frequency searching.
    CF 1.6 looks very nice by the way
    /M
    Constant Bitrate superbowl's Avatar
    Jan 2005
    Germany
    Hi Maximus,
    are you sure, that Destinator is able to use the TMC data ?
    As far as i know, Destinator ist *NOT* able to use TMC correctly.
    Thats the reason why i switched the software for my pocket pc from Destinator to Tom Tom.
    - Superbowl
    i never drink water cos fish ***** in it. (w.c. fields)
    D3 doesn't but I got the impression that D5 would.
    Quote Originally Posted by David
    It will be sold with an OEM version Destinator based on their 5 series navigation application with integrated RDS traffic and much more....
    Jan 2005
    Germany
    Quote Originally Posted by Maximus
    That would be good news, but iīd like to see that first. A friend of mine is working in that business .. and my last information is that right now destinator canīt use TMC.
    But .. time will show.
    - superbowl
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    D3 does not do TMC - but watch out Freedrive may via another route.
    NB - TMC in the EU is free in GB you have to pay for it now so most PDA software dont even support it currently either.
    Terran
    Jan 2005
    Germany
    Hi,
    how do they handle it ? As far as i know, TMC is a service like RDS, which is sent out via the radio broadcast-signal.
    How do they distinguish who has paid a fee and who hasnīt ? That should only be possible in the navigation software.
    Back to Destinator .. my actual information is that Destinator is still not able to use the TMC signals.
    - Superbowl
    Jan 2003
    Quote Originally Posted by superbowl
    Hi,
    - Superbowl
    RE TMC - its software locked out... with out the codes etc its hard to use even though you can pick up the signal.
    Re Freedrive - its would use data across the net from several free better sources...
    Terran
    May 2003
    Germany
    And it's wrong ... Destinator PN (should be what others are calling "5") does support TMC. You have to use a TMC enabled GPS device for this.
    In a german radio projekt, they are using 2 tuners, as one is doing background scans and/or collecting rds/tmc data. A way to handle TMC would be multiplexing gps and tmc data on a virtual serial port, so it looks like a "real" TMC enabled GPS device.
    Jan 2003
    Quote Originally Posted by krog
    Contry dependant... see pocketgps.co.uk for more info...
    Terran
  1. PhoCo support in CF 1.4?
    By tHaHooL in forum Centrafuse
    Last Post: 08-08-2005, 04:44 AM
  2. OBD2 Support in CF 1.4 ?
    Last Post: 08-05-2005, 11:15 AM
  3. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  4. Flash OS
    By BiohazrD in forum General Hardware Discussion
    Last Post: 12-04-2004, 09:57 AM
  5. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
