Results 1 to 10 of 13
Thread: CF 1.5 running slow
    Low Bitrate Linde's Avatar
    Jan 2006
    Sweden
    CF 1.5 running slow
    Hi,
    I know this problem has been well known from before
    But Im just qurious.
    Running a Via SP 13000, 512, onboard video.
    And CF 1.5 running so slow. Recomended spec is 1Ghz but, its like sitting with a old 386 ...
    Is there any light in near future or is this the way it is?
    I realy like this frontend, will buy it if it works faster later.
    Or is this problem just my system?
    Please give me a answear.
    Daniel
    Sweden
    Constant Bitrate OoNikFraleyoO's Avatar
    Mar 2005
    Alabama
    It should be better with the next release.
    Low Bitrate tC_install's Avatar
    Nov 2005
    Hollywood
    Hows the rest of your system run?
    Scion tC 2005 with DWW-700H
    Via Eden M10000, 512MB, 100GB 5400rpm, Xp Pro
    Jan 2006
    Sweden
    Quote Originally Posted by tC_install
    The rest runs pretty good, nothing to hang up on.
    Its big different between in windows and in CF.
    Nov 2005
    Hollywood
    Check the error.log file. Maybe something in there can indicate why its slow.
    Have you tried re-installing centrafuse?
    Jan 2006
    Running a Via SP 13000, 512, onboard video < I also tried using sp 13000, the graphics card is totaly ****. If you install powerdvd 6, and use it for the mpg decoding the hardware axx in the onboard card works making it run at 70% on dvd playback.
    However Centralfuse dosent like the Cyberlink mpg codec, it locks up the PC (pc just freezes)
    The only solution I can find is ither find an aletrative fast mpg codec that lets you enable hardware axx, or get a PCI graphics card.
    I gave up the sp1300 and used a shuttle 3.2 gig instead.
    Nov 2005
    Hollywood
    Screw that.
    Use this. www.videolan.org
    Get the VLC player from there. I use a Via M10000. Xvid hdtv (480p) content runs clean.
    Jan 2006
    Sweden
    hmm sounds like I have bought junk! Doh!
    But he who is doing this program. David?
    Isint he using a M10000 board??
    Isint that thesame almost as the SP 13000? just faster cpu?
    I can&#180;t imagine hes program is running this laggy. :/
    Nov 2005
    Hollywood
    Im using the M10000 board as well. Centrafuse isn't as fast as winamp. But its runs just fast enough for me to find it very usable.
    Did you check the error.log file?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    CF 1.5 runs slow on VIA. Its just too buggy to use. End of story.
  1. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 10:11 PM
  2. CF 1.5 - Where i can buy GPS-maps?
    By tHaHooL in forum Centrafuse
    Last Post: 12-26-2005, 01:30 AM
  3. CF 1.5 navigate me to the wrong city
    By kranze in forum CF Bug Reports
    Last Post: 11-22-2005, 12:51 AM
  4. CF 1.5 DVD not playing
    By Zboss1 in forum Centrafuse
    Last Post: 11-21-2005, 08:44 AM
  5. Making a CF card bootable
    By kpjuk in forum WinNT Based
    Last Post: 01-24-2005, 06:16 PM
