Results 1 to 10 of 15
Thread: Is this Possible? I'm sure one of you smart guys can help me :)
    May 2005
    Champaign IL
    I would like to make a button called "VIDEOS" and have it link directly to my video paths folder.
    As of now I have to click on MEDIA >>> VIDEO PATHS >>> to access video.
    Does anyone know how to make a button that links directly to that folder? David?
    All help is appreciated
    Aug 2004
    Black Hills, SD
    You are stuck going through media then video paths to access your vidoes.
    Hardware: VIA Epia MS 12000, 512 DDR, 60GB HD, 7" Xenarc, GM-210, Wi-Fi, Bluetooth, Radio Xtreme
    Software: Centrafuse2, Phonecontrol.net, nLite, TopoUSA 5.0, iGuidance, Girder, Winc
    Low Bitrate tC_install's Avatar
    Nov 2005
    Hollywood
    Quote Originally Posted by Anointed
    Make a batch file that has this in it:
    start explorer c:\path\to\myVidzDir
    Save it to "c:\Program Files\Flux Media\myVidzDir.bat"
    Create a new ext. app put in the app name, patch to the bat fileapp name the window name (make one up) . It wont show up unless you put all three.
    Map your new VIDEOS button to the new ext. app you created.
    Scion tC 2005 with DWW-700H
    Via Eden M10000, 512MB, 100GB 5400rpm, Xp Pro
    Raw Wave justintime's Avatar
    Apr 2005
    the approach tc_install suggests might work, but the issue is that CF wants to embed anything you configure like this. It might open a DOS COMMAND window and embed it when you run it, which will look ugly. Plus, you would have to manually exit it from CF every time.
    I have asked David to allow people to run applications without embedding, but he either doesn't understand the need, or thinks it is not a need altogether. Go figure!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Nov 2005
    Hollywood
    Cool
    If you aren't digging the command prompt then just point the ext. app to launch c:\Windows\explorer.exe and give of c:\myPath\to\Video as the app. param/arg.
    No batch file needed really.
    Also,
    • make sure the setting "on top" is off.
    • and write in the window title of whatever the directory is.
    Unfortunately, my Centrafuse on my laptop is complaining about registration (AGAIN!!!! ARghh!) so I cant test this no batch file method out .
    Lemme know if this works for you.
    VENDOR - Centrafuse veetid's Avatar
    sorry about the registration problems... It was a mess up with the year rollover and 1.5 license files... I am working hard to get 1.6 out, but the move I just made across the country killed 2 weeks of productivity....
    david
    May 2005
    Champaign IL
    TC_INSTALL I tried the 2nd idea and what it does is open up the VIDEO folder in windows. It did show up full screen but when you exit centrafuse it Shuts down the entire windows explorer and the windows error message pops up. Let me know if you get the same thing
    Nov 2005
    Hollywood
    I wish I could try right now. My laptop wont take any new license files.
    No biggy. My car is still running fine (I hope). I have it working very nicely with VLC and the batch script file in the car.
    At the moment I plan to uninstall all my mpeg4 codec/programs and install ffdshow and acfilter. That should make my video files play a lot better within Centrafuse natively.
    Sep 2005
    Pomona, CA
    You mean it shuts down the Windows Explorer window or Windows Explore?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    Nov 2005
    Hollywood
    Do you have Centrafuse running as shell?
  1. Screw you guys JK
    By Moneyfink in forum Power Supplies
    Last Post: 07-24-2005, 09:53 PM
  2. Acura 3.2tl Just Finished Tell Me What You Guys Think
    By Desisolja2 in forum Show off your project
    Last Post: 06-17-2005, 05:47 PM
  3. What do you guys think of this new technology? The DVpod
    By SoloSL203 in forum General Hardware Discussion
    Last Post: 05-06-2005, 02:34 AM
  4. how did you guys anchor your computers in the trunk?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 09-15-2001, 11:30 PM
