Results 1 to 5 of 5
Thread: DeLorme Street atlas won't embed in CF?
    Jul 2005
    Alright problably a n00b question, but i've been looking for the answer all day and haven't found quite the answer to my question.
    Alright i have tried to embed Street Atlas as an external App. This in itself is pretty easy, just follow the directions.
    Where i get into trouble is when it starts. It starts fine, but in its own window, not inside CF. cf has a window that is all white that has hte window name on it and can go full screen and back, but it doesn't actually have SA maps in it. the program runs as if i started it outside of CF
    Anybody know what im doing wrong, if its already been posted somewhere, a pointer to the thread would help.
    PS: I tried using SKINbedder, but i am not sure what i am doing with it and was only able to obtain the same results as if i embedded SA by itself.
    Sep 2005
    Pittsburgh
    Ya I have the same problem. But quite frankly I don't really want Delorme to embed correctly... the program would just look too small to be useful on my 7" touchscreen. If the problem is that you can't get back to the Delorme screen from inside centrafuse, I would try using AltTabber program that you should be able to find in the forums somewhere. The alttabber program puts a small translucet box anywhere you desire that execute an alt-tab when you touch it.
    '03 Hyundai Elantra
    Pioneer 7600 Head Unit
    Dual 12" Subs w/ Rockford Amp
    Carputer:
    VoomPC w/ M1-ATX PSU
    VIA MII 12k w/ 1GB, 40GB 2.5" HDD
    Wi-Fi, BT, DVD-ROM
    7" Xenarc 700TSV
    WinXP Pro, Delorme SA2006
    Constant Bitrate djchicago's Avatar
    Chicago Ill
    "the program runs as if i started it outside of CF"
    Well it is, when u place a app into CF it is still a ext App thats why the window
    in CF is not used, u havent done anything wrong
    Jul 2005
    I actually got it working today, i just put DeLorme Street Atlas as the window name and it started up inside CF, i have it set so that the bottom bar is hidden and hte side map is off, the map is plenty big enough to do what i need it to, it will keep me happy till i can get a full version of destinator in a future release of CF. thanks for the input.
    Newbie Imobejoas's Avatar
    Jan 2005
    I do the "double restart" The first time I run CF (running 1.3 or older I forgot) I run delorme GPS, and then exit everything. I then restart it and it embeds perfectly.
  1. Replies: 21
    Last Post: 03-07-2006, 11:43 PM
  2. FS/FT: Delorme Street Atlas 05 Original CD
    By xdjxklusivex in forum Classified Archive
    Last Post: 09-15-2005, 01:50 AM
  3. CF and Street Atlas 2005
    By evandude in forum Centrafuse
    Last Post: 09-01-2005, 06:18 PM
  4. Replies: 1
    Last Post: 08-25-2004, 12:29 PM
  5. Replies: 9
    Last Post: 06-11-2003, 08:33 PM
