Results 1 to 3 of 3
Thread: Mixer problem: SUB slider contorls center channel
    Jan 2006
    Mixer problem.
    On my soundcard the SUB meter controls center channel. I tried "swapping" center and sub channel on the soundcard driver. It gets swapped allright, but the SUB meter still controles the CENTER channel on my system.
    Any way to fix this ? Center\SUB is in the same JACK. I am currently running a 5.1 setup.
    except from this I have succesfully got CF to use the ac3 filer and ffdshow correctly for 5.1 Analog output. The sub slider controlling the center channel insted of the sub channel is my only problem left.
    VENDOR - Centrafuse veetid's Avatar
    I will take a look at it... So you have a seperate Center/Sub output? A lot of soundcards only have one, so I just labeled it sub... you can change that label to say Center in the language file...
    david
    Jan 2006
    Quote Originally Posted by veetid
    david
    I see.. nice that you can change the label on the sliders.. The problem is that its not intersting to control center (since volume up\down does increase\decrease all the channels, but the sub Channel would be very neat to control seperatly.
    Please check out the aspect ratio tread to see my setup of FFDSHOW and AC3filter (importaint to set the FFDSHOW to realtime encode to 5.1 AC3 digital route to see the problem, When used on ANALOG 5.1 it works, but is a bit unstable):
    Aspect Ratio..
    I know that what I posted is a bit on the sidetrack of the tread, but the problems are related. it actually has something to say if u use dual screens or analog only or digital only realtime encoding to ac3 for what acctualy happens with the video playback
    Screencap of the config for the soundcard:
    Anyway I have to say I love Central Fuse, The Dual Head support and general GUI is awsome.
  1. slider problem
    By btbe in forum RR Skins
    Last Post: 07-16-2006, 03:32 AM
  2. How does this setup look and a potential hookup problem
    By Options20002001 in forum Car Audio
    Last Post: 08-16-2005, 09:44 PM
  3. slider problem (mixer module)
    By predator1 in forum CF Skins
    Last Post: 07-23-2005, 07:57 AM
  4. Mixer Problem
    By nws@basti in forum Road Runner
    Last Post: 07-18-2005, 07:19 AM
  5. Rescaling skin an song position slider problem
    By Passe in forum RR Bug Tracker
    Last Post: 02-24-2005, 12:34 AM
