Results 1 to 6 of 6
Thread: CF/iGuidance/SkinBedder Combo?
    Sep 2005
    Pomona, CA
    I would really like to get CF to work with iGuidance and Skinbedder, but I don't know which versions work together well and how to get them to work. Right now I have CF 1.5, but when I try to go from iGuidance to DVD player it crashes. What's a good combo?
    Also, I'm not that sure on how to use Skinbedder...I kinda got it to work, but not well. I've looked all over the SB forums and haven't found any good instructions, anyone know of any?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Try version 2.9999 if v3 doesn't work for you.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    I've found that an older, less frilly version (2.5?) of skinbedder worked better for me than the newer versions. It still required some initial tweaking with regard to window positioning, but it seemed to run alot smoother and quicker.
    Sep 2005
    Pomona, CA
    I've been using 2.9999 - I'll try 2.5 also.
    Any thoughts on getting iGuidance to work with CF better? Everytime I embed it into CF and then go to the DVD player it crashes. Maybe I should embed PowerDVD??
    Carputer Progress:
    Teardown PC [100%]
    Oct 2004
    no suggestion on the dvd issue, never had an optical drive attached to the carputer. what dvd player are you using? the interal cf dvd player, or a different program?
    Sep 2005
    Pomona, CA
    So far I've only used the CF DVD player. I don't plan to use the DVD drive either, but a virtual drive with DVD images on a HD. Either way, the CF DVD player crashes CF when iGuidance is embedded.
    Carputer Progress:
    Teardown PC [100%]
  1. Cool & quiet combo for sale
    By linden_arden in forum Classified Archive
    Last Post: 04-19-2005, 04:24 PM
  2. Source for Combo Antenna
    By antimatter in forum General Hardware Discussion
    Last Post: 01-27-2005, 10:48 PM
  3. Great wireless mini keyboard/mouse combo
    By mrgerbik in forum Input Devices
    Last Post: 09-30-2004, 07:16 PM
  4. using this LCD/keyboard combo
    By hannibal in forum Input Devices
    Last Post: 08-21-2004, 01:35 PM
  5. Replies: 0
    Last Post: 07-27-2004, 12:32 PM
