you should be able to go to tools and then into settings... There is an option to set startup/shutdown commands. Simply click it, then select when you want the command to run and hit ok, then hit the "+" sign to add a startup command... From this second dialog you will be able to select an exe... You can also specify optional parameters... just hit cancel or enter with nothing typed if you don't want/need any parameters...
david
LinkBack URL
About LinkBacks
